Setting up 003 rack + I/O list with Protools 12
I've been attempting to properly set up my I/O list on protools 12, in accordance with the 003 rack plus (after a year of not touching any DAW) so please excuse my ignorance. I've deleted all paths for input, output, bus and selected default for all three. I'de like to set up a path for my monitors on the output tab but my analog outs only go up to 9, Optical 10-16, and S/PDIF 17-18. The 003 rack plus has 8 line outputs and a separate out for monitors. Shouldn't there be an extra 2 analog outs for the monitors instead of stoping at 9? I'm so lost.
Re: Setting up 003 rack + I/O list with Protools 12
Just Go to Setup, Playback Engine, and Check first if 003 is set as Playback Engine!!!! then Go to i/o settings and just click on input tab click on default, as well on the output tab, click on default, and you will see all i/o from 003...
Pro Tools 2021.12 UAudio Apollo X8, 8 Duo & Apollo Twin. Mac mini M1 8 on Ram, 256gb, Thunderbolt 3 KRK V88. Yamaha HS7 Korg ESX-1 MBOX2 003Rack Producing My Own Life |
The 003 Rack plus is selected as the playback engine, I have selected default for both input and output but the output still only shows 9 analog outs. The rack has 8 outputs to use and then the separate monitor outputs. Shouldn't this result in 10 analog outputs on the I/O list?
The monitor output will simply output whatever is being sent to Output 1-2.
There should be 9x stereo outs total = 18 outputs ... 8x analong ... 8x ADAT ... 2x SPDIF The 'Main' and 'Alt' monitor outputs are a mirror of analog outputs 1/2, unless you press the 'Aux In' button in the monitor section on the front panel, in which case whatever sound connected to the 'Aux In' sockets is send to the mo itor outputs. So you can't route audio to the monitor outputs separately and independantly. This is different to how some other audio interfaces work, where for example UAD Apollo and most MOTU interfaces have their monitor/main outputs available to route audio to independently of analog outputs 1/2. The 'Main' and 'Alt' outputs are for connecting two sets of monitors, and audio is routed to the 'Main' outputs unless the 'Alt CR' button is pressed, in which case the audio is instead routed to the 'Alt' outputs.
Mac Pro 2009 with 2010 firmware, 12-Core 3.46ghz, 64gb RAM & working Thunderbolt, OS 10.14.6 and Windows 10 iMac 2012 27", 3.4ghz i7, 32gb RAM OS 10.14.6 Digi 003 Console for control surface only, Focusrite OctopreLE and MOTU Traveler for extra analog-ADAT conversion, UAD Apollo Quad Silver with Thunderbolt card, Apollo x4 and pci-e Octo, Adam A77X monitors. Pro Tools 2022.4, Media Composer 8.9, Sibelius 8.7, Cubase Pro 11, Wavelab Pro 11, Logic Pro X 10.5.1, Mainstage 3. Various apps, soft synths, FX plugins. Plenty of hardware synths, rack gear, microphones etc. And then there's the studio ;-) |
I have 003Rack, and just has 8 Analog Outs, monitor Outs are only for monitoring control!!!
Need some help setting up ProTools to record with Eleven Rack | thrashmetl | Eleven Rack | 19 | 08-11-2013 11:11 AM |
need help setting up protools 8 le with motif rack and trition rack(so newby to this) | BeatBoy19 | MIDI | 0 | 06-01-2011 10:38 PM |
Setting up Eleven Rack on Mac OS 10.6.3 | stratman.0426 | MIDI | 1 | 05-21-2010 01:16 AM |
Setting Up I/O w/ C24 and 003 Rack | got2bjab | ICON & C|24 | 0 | 05-17-2010 07:57 PM |
setting up 003 Rack with MacBook Pro..Help Please | pguy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 10-08-2008 12:01 PM |
