PT 9 Efficiency Questions
I have the following....
MacPro 8 Core (2009) UAD 2 Quad Card 12 Gigs Ram PT 9.01 Black Lion Audio 003R Question is.... Can someone explain how much of my computer I am able to use under PT 9? How much ram am I actually able to use? I am reading 3 gigs max for 32 bit? If so what do I have to do to take full advantage of 12 gigs of ram and 64 bit? Am I limited to 4000 samples for ADC? Any other input would greatly appreciated. thanks
Hackintosh Intel Core i7-3770K Quad-Core Processor 3.5 GHz 32 Gigs RAM UAD 2 Quad Card UAD Duo Apollo w/Thunderbolt |
Re: PT 9 Efficiency Questions
All of these questions are in full swing in various current threads. Have you searched the message board for these answers? I have the time, so I'll go through it with you to the best of my collected knowledge...
-You can use all of your processors but it is advised to use a few less than you have so that your computer doesn't choke while trying to do other tasks. People have been reporting odd numbers for the best results (such as 3,5,7 processors etc) -Protools can only access 3-4 gigs because it runs in 32bit. This is a major complaint right now, and we're all assuming Avid is hard at work to make a 64bit version asap. It will likely be a while as apparently it's a ton of work. Yes everyone else is already there-no they aren't faced with legacy hardware support (there will likely be some HD users that would be terribly upset if a stock version of PT was more efficient than their huge investment for HD) -All that said, in order to use your system to it's full capacity, you can either wait for PT to "catch up", or use Vienna Ensemble, or other DAW's with rewire. I'm not entirely educated on this process but if you SEARCH THE DUC, you will find a vast amount of information regarding those methods. -Yes, as far as I know that's the limit for ADC. I'm guessing you're asking cuz some Waves plug is generating a billion or so samples of delay? I'm nowhere near as experienced as some of the members here, and if I've gotten something wrong here they'll kindly/quickly correct me, but by this time, they're likely sick of answering the same questions daily. Dude, you'll honestly find the best answers by spending a little time searching around here.
-Mac mini i7 Quad 2.3, 4g ram, OSX 10.10.2, PT11.2.1, iLok 2. -Apogee Quartet, 2 Profire 2626's. |
thanks for the reply...I have been digging through the threads for awhile, but they seem to get off topic alot and thought a new thread with specific questions would help.
thanks again for the reply...
Nice. The facility I work at has these as well.
Jonathan S. Abrams, CEA, CEV, CBNT Apple Certified - Technical Coordinator (v10.5), Support Professional (v10.6 through v10.10) |
PT 11 efficiency? | climber | Pro Tools 11 | 6 | 09-12-2013 09:16 AM |
Osx vs Win7 efficiency? | tamasdragon | General Discussion | 4 | 05-02-2010 11:45 PM |
Protools efficiency...... | Synchrometer | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 03-10-2004 11:01 AM |
Protools efficiency...... | Synchrometer | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 03-08-2004 06:54 PM |
increasing the CPU efficiency... | aziel | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 03-02-2003 05:35 AM |
