SINC PT24MP AND CAKEWALK USING WIN NT
HI; I'VE A BIG PROBLEM...I NEED TO SINC CAKEWALK AND PRO TOOLS 24 MIX PLUS IN A IBM COMPATIBLE PC USING WINDOWS NT. I WAS WAITING FOR A PROGRAM THAT WAS CALLED LOGIC AUDIO FOR NT WITH WHOM I COULD USE THE TDM PRO TOOLS USING THE UNITOR 8 LIKE MIDI INTERFACE...BUT...BUT...THE PROGRAM DID'NT COME, THEY SAID THAT IT WON'T COME...AND NOW I DON'T KNOW HOW TO DO...I ACCEPT ANY IDEA OR INFORMATIONS ABOUT THIS MATTER...AND I OFFER TO WHO WILL SOLVE IT A WONDERFUL VACATION IN ITALY)))...BYE, WAITING AND HOPING.....
Re: SINC PT24MP AND CAKEWALK USING WIN NT
Well, the way I do it is to run PT on one machine and Cakewalk on another. Either feed SMPTE to both, or MTC from PT to Cakewalk. If you're just using one machine, try Sonic Foundry's Virtual MIDI Router to send MTC from PT to Cakewalk...although I haven't tried this myself.
-------->Denny Conn |
I use cakewalk pro audio 8, withuou the audio.
I use a mq 8portse and send a midi sync from PTNT to the 8th port, I connect a midi cable from the 8th port out to the 8th port in and set cakewalk to receive midi time code. It works all on the same machine. If you need futher information write me [email protected] |
Hiya
Nice shouting... I use PTNT with cakewalk all on the same machine using MIDIOX (a free program already mentioned a few times on this board, now in v5.5 so it is an amazing piece of software for precisely nada)) which creates virtual midi ports so you can synch your programs without needing to patch anything externally. No wires. No mess and it actually works! The above solution assumes you are not using the audio properties of CW. You can't control PT from cakewalk without seriously limiting PT capabilities... don't do it! No reason though why you can't use the audio of CW as well as PT using a local drive and a soundcard. Then again, why? You can download midiox at http://members.xoom.com/MIDIOX/midiox.htm Drum |
Does the vacation cover for airfare costs?
Use two machines. One for PT on NT, and another for Cakewalk on Win98. Have USD? Will have no frills sync to your MIDI interface! Disable MIDI thru and you're on the go! Enjoy! |
digi oo2 sinc with a creamware | nachonieto | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 12-05-2008 04:20 AM |
Ashley Simpson.....SNL lip sinc disaster | Dogcode | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 112 | 11-07-2004 10:11 PM |
PT HD at 96 k not holding sinc | Byfar Prod | Pro Tools TDM Systems (Mac) | 3 | 09-18-2002 12:47 AM |
Sinc with beta or dv machines | fcpercinotti | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 12-21-2001 08:25 AM |
Pro tools mix+ mtpav sinc with logic | Vizo | Pro Tools TDM Systems (Win) | 0 | 06-14-2000 03:35 PM |
