Old 04-01-2002, 09:49 PM
Eric Baragar Eric Baragar is offline
Default PROBLEM - Battery and PTLE
I bought NI Battery for my ProTools LE Digi001 rig a week ago and I can only get half of the program to work. Here's the problem
I have been able to get Battery to respond to MIDI input, produce audio drum sounds and to record a MIDI track, but I cannot get Battery to play back the MIDI track.
I have checked out the Battery/PTLE posts on the DUC and my expert retailer has not found a solution, although there are posts on the DUC from users who have successfully installed the Battery / PTLE combination.
MAC:
G4 733, 384 Mg RAM,20 Meg HD
DIGI 001
EMagic mt4
PTLE V 5.1.1
OMS V 2.3.8
DirectConnect V 5.1.1
Battery:
Battery V 1.0
Audio Port - ProTools DirectConnect
MIDI Settings - Selected MIDI System = OMS, MIDI Input Device = 01/W, MIDI Output Device = Battery, all other settings = off
BatteryPI is located in System\DAE\Plug-ins\
MIDI track:
Input from MIDI controller (01/W FD) receives MIDI
Output assigned to Battery (tested various MIDI channels) responds to MIDI Controller
* A recorded MIDI track does not trigger Battery samples during playback
AUX track has Battery plugin
Battery DirecConnect output 1L/2R (same as Battery output assignment)
Input assigned to various inputs (to test)
Output assigned to Analog 1-2 - to audio monitor amp
BTW... Once this setup is loaded, I can trigger the Battery samples from the MIDI controller regardless of what application is in front and regardless whether the record is enabled on the MIDI track.
Native Instruments has not replied with my password after I registered on their website so I have not been able to get any help from NI.
Any suggestions???
Thanking you in advance
eric.baragar@sympatico.ca
Eric Baragar
BigBMusic
http://www.bentwoodrocker.com
Old 04-02-2002, 09:48 AM
grewol grewol is offline
Default Re: PROBLEM - Battery and PTLE
Hi
You should switch Battery input to IAC Bus instead of 01/W.
Midi track should have output to IAC Bus too.
Check OMS setup first, if the IAC driver is listed there and it's active.
Greg
Greg
Old 04-02-2002, 04:07 PM
[img]images/icons/smile.gif[/img]
Setting the Battery MIDI Input Device to Battery worked!!!
Thanks for your simple solution to an aggrevating problem
Eric Baragar
BigBMusic
Using NI Battery 3 with PTLE easatduc 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 12-26-2007 01:40 PM
Battery 2 and PTLE n3xus 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 06-24-2006 12:23 PM
PTLE 6.7 and Battery 1--Multiouts? whtrabit 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 12-13-2004 11:12 AM
Battery/PTLE questions guitaramundo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 12-12-2002 08:11 PM
Anybody Using NI BATTERY with PTLE/Windows Bassguitar 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 05-10-2002 03:33 PM
