Pro Tools 9.0.5 freezes after FRESH install of Lion
Last night, I reformatted my MacBook Pro and reinstalled a fresh copy of Lion using a bootable USB stick. I installed Lion and the 10.7.1 update. After installing iLok drivers and the 9.0.5 FULL installer, PT still does not boot! It loads all the plugs into Xpand.dpm, and then crashes. I have NO 3rd party plugins loaded yet, only the stock Avid plugins. Any tips?
Conrad |
Re: Pro Tools 9.0.5 freezes after FRESH install of Lion
I have exactly the same problem.
I just received my Protools Box, I started to install it on my all new Macbook Pro with Lion and after 2 clean install and update, Protools crashes just after loading xpand.dpm. Please HELP ! |
I did have the same thing happen, but after re-starting the computer, it works.
Not sure if this is the solution for everyone, but I heard it has something to do with another app (I think iChat), that does something to the system or core audio that has to be "flushed" by the re-start.
Macbook Pro 15" 2.66 i7, 8GB RAM / 10.11.5 / Pro Tools 12 / Komplete Ultimate / EWQLSO Gold Play Edition / Steven Slate Drums / Logic Pro / Apogee Duet |
Thank you so much ! It works !
I deactivated the automatic launch of all my applications (including iChat), restarted my computer and Protools has finally started. You saved my 3 next mixing sessions to finnish before the end of month...! Musicals regards, Aurélien. |
Another similar occurrence here - installed PT9.0.5 onto new MPB running Lion - PT hung at the xPand! plug - cancelled and rebooted then PT9 started perfectly.
Re: Pro Tools 9.0.5+Mbox 3 pro +Lion
with my mbox 3 pro with pro tools 9.0.5 and lion the keys speaker select do not work I have to change the monitor speakers from the internal mixer, if the detachment firewire keys instead of work,
they are beta drivers for the Mbox 3 Pro for lion? when will come the final drivers? thanks bob |
Pro Tools will not open on fresh install | jeff5x0 | Pro Tools 10 | 15 | 02-16-2013 09:02 AM |
Pro Tools 8 LE really buggy on a fresh install | rubberhead | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 11 | 09-21-2012 01:01 PM |
Pro Tools 10.2 Fresh Install Fixes issues | chuckgreenjr | Pro Tools 10 | 7 | 06-15-2012 01:47 PM |
Clean install of PT 10 under fresh install of Lion | bortraws | macOS | 0 | 10-24-2011 08:53 AM |
Fresh install of Pro Tools Le 6.4 | cherrancemetal | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 02-01-2011 10:21 AM |
