Old 02-04-2011, 12:56 AM
gonzolagonda gonzolagonda is offline
Default Corrupted WAV file
Upon re-opening a session I'd worked on only an hour beforehand, I was confronted by the Missing Files dialogue - one mono vocal file was missing. It had played back perfectly only an hour beforehand. Upon searching, it looked to be present in Finder and the workspace window, but was now unreadable by PT. I'd even backed up the session by dragging onto another drive when I'd worked on it earlier, but that copy too was unreadable. Tried importing the audio file - didn't initially get the familiar message that it was unreadable by PT, but it was showing no info such as duration, channels, bit depth and sample rate, and it wouldn't import. Logic can't read it, nor can Sound Forge on a PC, so I guess it's lost forever. Would like to know what caused the corruption though...
PT12.4 HD - UA Apollo 16Mkii - UA Apollo 8TB Duo - Mac Pro 2014 6-Core 3.5GHz 16GB RAM - OSX 10.10.5 - Magma ExpressBox3T - UAD-2 Octo - Euphonix Artist Mix, Control and Transport
Old 02-04-2011, 01:14 AM
crizdee's Avatar
crizdee crizdee is offline
Default Re: Corrupted WAV file
Maybe try Rail Jon Rogut's Wave saver..
http://www.railjonrogut.com/
scroll down its on the left!!
See below regarding this app from Rail, Wave Fixer http://www.railjonrogut.com/WAV%20Saver.htm
Chris
Producer, Engineer,
Slow Readers Club_Build A Tower top 20 UK album charts
www.ukmastering.com
PT10.3.10 Mountain Lion HD6 accel Magma PE6R4 Control 24 MacPro 12 Core 3.46ghz UAD-2 Octo x2. Manley Vari-Mu, Manley Massive Passive, SSL VHD, ADL600, Grove Tubes ViPre, Tube-Tech CL-1B. Hafler TRM active monitoring.
Old 02-04-2011, 01:25 AM
Wrong app...
check out this thread and find my Wav Fixer app.
http://duc.avid.com/showthread.php?t...ighlight=Fixer
Rail
Platinum Samples
www.platinumsamples.com
Engineered Drums for BFD
Old 02-04-2011, 04:01 AM
crizdee's Avatar
Originally Posted by Rail Jon Rogut View Post
Wrong app...
Rail
Chris
Producer, Engineer,
www.ukmastering.com
Old 02-04-2011, 06:05 AM
I'm afraid no luck with that. Tried on two different PCs, Windows 7 64 bit (and in compatability modes for XP and W98SE) and on a PC with XP SP3, and on both the program always immediately crashes when I hit the Repair button (showing 0 bytes processed!)
Old 02-04-2011, 10:04 AM
Look for WAV FIXER in http://duc.avid.com/showthread.php?t...ighlight=Fixer
Rail
Platinum Samples
Old 02-04-2011, 10:05 AM
Originally Posted by crizdee View Post
Wrong app Chris!
Rail
Platinum Samples
Old 02-04-2011, 10:14 AM
Top Jimmy's Avatar
You could try Audacity. It has an Import>Raw Data function. Choose the file and set the appropriate attributes (bit depth, endianness, sample rate). I've been able to recover the audio from corrupted files with this.
James Cadwallader
Hackintosh - Gigabyte Z77X-UP5TH, Intel Core i7-3770K, 32GB 1600Mhz DDR3, 2x SATA 6Gb/s 240GB SSD, 3x SATA 6Gb/s 1TB HDD, 1x Glyph 2TB USB3 HDD, Sierra 10.12.6.
Pro Tools HD 2018.12, Focusrite Red 8Pre, Mbox 3 (Mac)
Pro Tools 11.3.2, Mbox2 (Win 7)
Old 02-04-2011, 10:27 AM
Or just use my correct app...
Use the app I posted to repair the file(s) (in that thread).
http://www.railjonrogut.com/downloads/WavFixer.dmg.zip
This will fix the WAV files which have lost their FMT chunk.
You may select multiple files and need to tell the program the sample rate and resolution of the files.
It will create a copy of the bad file and then repair the copy - it will not allow the source and destination folders to be the same.
Rail
Platinum Samples
Old 02-04-2011, 10:52 AM
Boy, that was hard to find (11 page thread!)
But, wow, it worked!!
Thank you so much Rail (and Chris)!
Corrupted .ini file? GTBannah Windows 5 11-18-2012 08:16 AM
Corrupted file PT 10.2 mac os x wildfifteen macOS 1 06-06-2012 07:46 PM
Corrupted Session file TULL 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 02-17-2005 09:02 AM
HELP! Corrupted file! GrantE General Discussion 0 04-21-2003 07:44 PM
Help with Corrupted File in HD (Urgent) everglass Pro Tools TDM Systems (Mac) 6 06-29-2002 06:10 AM
