Old 01-16-2004, 10:58 PM
nikko nikko is offline
Default Busses/Sends
Hi there. Sharon here. What's the difference between Busses and Sends.When do I use one or the other? Don't both route copies of the signal? Toodles:)
Sharon
Old 01-16-2004, 11:26 PM
Default Re: Busses/Sends
A buss refers in the analog domain to a summing buss... basically a piece of wire (busbar) which runs the length of the console.. and each track can be summed into the buss by pressing a buss switch. A send is similar in that it's also a piece of wire that runs the length of the console.. but each track is summed into it via a "send" potentiometer.. which means you can vary the amount sent to the buss.
In Pro Tools.. you use a send fader assigned to a buss.. or you asign the outpt to the buss... here you have some flexibility as to how the same buss "wire" is used.
Rail
Platinum Samples
www.platinumsamples.com
Engineered Drums for BFD
Help with Sends and Busses please!! achtungbaby macOS 2 09-07-2011 04:54 PM
SENDS, AUX and busses???? :confused: MUKULIA DESIGN Pro Tools SE and Essential (Win) 1 02-22-2010 03:12 PM
Newbie Question about Aux, Sends, & Busses Pro Tools LE 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 10-09-2005 01:40 PM
Naming sends/busses Bezo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 10-07-2003 11:51 AM
A question about sends/busses Przemek Tips & Tricks 2 10-12-1999 06:00 PM
