Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools 2020
Old 11-22-2020, 02:44 PM
gcasper gcasper is offline
Default Tempo mapping of audio
I've got a choral piece I'm working with, so this is live audio. The piano accompaniment was not recorded with a click track, and so is not beat accurate. Which does lend itself nicely to the sound of this number, gives it more freedom of expression. But my question is, how do I map the tempo that exists in this file, measure by measure, so that I can create a click track for the singers to follow? And to allow me to sync the voices with the piano correctly? There MUST be a way to do this with Beat Detective or with tempo mapping, but I can't find a solution anywhere online.
HELP!!
Ryzen 7 5800X, ASUS TUF Gaming x570-PLUS (WIFI) motherboard, 32gB 3200mhz memory, Windows 11 Pro, Focusrite 18i20, Raven Mti2, Protools Studio 2023.12.1
Old 11-22-2020, 04:08 PM
Marsdy Marsdy is offline
Default Re: Tempo mapping of audio
Use Identify Beat. It works really well in this scenario. You don’t need Beat Detective.
Dave Marsden
UK
Old 11-22-2020, 04:32 PM
Yeah, I FINALLY figured it out! I have to go measure by measure using Identify Beat, then have to go back and tab to the end of each measure to put in the next measure number. VERY time consuming! But, it worked! Thanks for your reply.
Old 11-23-2020, 01:08 AM
Yes it’s labour intensive but the results are well worth the effort!
Dave Marsden
UK
Elastic Audio > drag drop loop > session not mapping to loop tempo 440Hz macOS 3 07-04-2011 07:35 PM
Tempo Mapping after the fact w/ Elastic Audio omoanya 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 06-15-2008 04:02 PM
Tempo Mapping KingStudios Pro Tools M-Powered (Mac) 0 06-05-2008 01:50 PM
Tempo Mapping stackatrack MIDI 2 01-23-2005 04:15 PM
tempo mapping in PT LE Brave Noise 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 06-25-2002 02:12 AM
