Old 03-05-2020, 11:38 AM
gcasper gcasper is offline
Default Installed latest version, now no sound! SOLVED!
All...
I just updated to 2019.12 from the previous release, and now have no sound output! Meters are jumping and everything appears to be working, but sound. I've reset my I/O settings, double checked my hardware settings... Still nothing. I'm using a Focusrite 18i20 interface. The native Focusrite app also shows the meters jumping, but no sound to my speakers. If I just play mp3 files from my machine, I hear those fine. But no sound from ProTools.
HELP!
Ryzen 7 5800X, ASUS TUF Gaming x570-PLUS (WIFI) motherboard, 32gB 3200mhz memory, Windows 11 Pro, Focusrite 18i20, Raven Mti2, Protools Studio 2023.12.1
Old 03-05-2020, 11:46 AM
Default Re: Installed latest version, now no sound!
First thing to double check is what is the playback engine set to in pro tools. Not "hardware settings" but Setup>Playback Engine>Playback Engine.
Old 03-05-2020, 12:04 PM
Southsidemusic's Avatar
And start PT with N key held down and when popup window shows choose your focusrite interface.
Then goto settings - i/o and delete all paths and press default ln all tabs in out aux etc and see if that helps.
Best Regards
Christopher
#thestruggleisreal
South Side Music Group
WEBHOME
Old 03-06-2020, 03:00 AM
Thanks for the input, but none of that worked. My playback engine is set to the Focusrite. The meters are jumping in PT, but still no sound. I have my Focusrite plugged into my Central Station for routing, but that hasn't changed either. And as I mentioned before, I can play mp3s just fine through the Windows media player, so I know the speaker connection to the Central Station is fine. Just can't get sound out of PT.
Any other ideas would be appreciated!
Old 03-06-2020, 06:44 AM
Did you do the i/o default options?
Best Regards
Christopher
#thestruggleisreal
WEBHOME
Old 03-06-2020, 09:31 AM
Yes I did. Still not working. I've even tried changing my Windows playback device. It's set to Speakers when playing mp3 music works, so I tried that, I tried setting to the Focusrite, I even tried setting it to the digital output of the sound card. Nothing worked.
Old 03-06-2020, 09:57 AM
btw, I also checked and reseated all my connections, so I know it's not that. Unless the output stage of the Focusrite has died!
Old 03-06-2020, 11:08 AM
ubxf ubxf is offline
I once had something like that going on and it ended up being the system set to digital sync with a bad clock.
Old 03-06-2020, 11:36 AM
And you have the latest drivers for the Focusrite and have the focusrite software program correctly installed and configured?
Best Regards
Christopher
#thestruggleisreal
WEBHOME
Old 03-06-2020, 12:54 PM
I'll check the clock sync when I'm back in the studio next week.
As for the Focusrite software, I think I'm on the current version, but I'll have to check that when I get back next week as well. Whatever is running now seems to be functioning correctly. The software sees the interface, the meters are bouncing in all the right places... So it appears to be functioning correctly.
Thanks again to all for the help. I'm quite perplexed by this one.
Avid Link app latest update.... no longer shows installed AIR plugs xrekcor AAX Plug-ins 7 01-20-2020 02:04 AM
Latest version. Cryos Avid S1, S3, Dock and Control App 6 08-01-2019 02:35 PM
(Repost) Finally Installed PT 9.0.0 See 9.0.6 Update Please Define-latest PACE driver KD11520 Pro Tools 9 2 10-21-2013 09:06 PM
Just installed PT10 and latest update, all working great! toner Windows 3 05-17-2012 07:14 PM
latest version of 6.1? Red Alert Pro Tools TDM Systems (Mac) 0 03-16-2004 02:44 PM
