Analog to Protools Transfer Problem
Hi y'all, beginning level Pro-Tools user (with a new MBox and PT 6.7), recently transferred 1/2 tape from a Fostex 16 track to a Mac g4 tower at a studio, and then we burned the PT files onto CDs which I loaded onto my G4 laptop. The problem is that playback of everything we transferred is fast-- about two semitones 50 cents high, give or take. Playback during original bounce to disk was normal. I tried using "pitch shift" to bring everything back down to the right tone, but it doesn't seem I can line up the tracks that way (they wander out of tempo--which they weren't on the fast playback). Someone said it's a time clock problem... but I have no specifics on how to fix. Have read reference guides and I don't see the issue addressed. HELP!!!
Re: Analog to Protools Transfer Problem
Use SoundHack and change the sample rate in the audio files' headers to match the data sample rate. Since playback is fast.. you need to change the sample rate in the header from 44.1kHz to 48kHz.
Rail
thanks for that Rail... I thought sample rate might have been the issue too, but it doesn't seem to be. I was there when we did the transfers/bouncing, and we definitely hit 48. On my powerbook running PT, the source and default match at 48... and remain mystified that I can't remedy this with a simple pitch shift... Maybe the problem was in the studio at the moment we transfered tape... but playback was fine as we bounced... or maybe the problem was burning the CD on the Mac at the studio... seems more and more like there's no other solution than to re-transfer and bounce everything all over again. Which is a pain, since the tapes are in California and I'm in New Mexico!
thanks anyway though-- R |
Your issue is guaranteed to be a miconfigured external sample rate mismatch.. your Pro Tools session was created as a 44.1kHz session.. and your external clock source was set to 48kHz.
Rail
Cluster Analog Transfer | digimog | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 11-14-2010 04:30 AM |
can you transfer my 1" analog tapes into Protools? | crushed | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 06-06-2008 08:30 AM |
Lock PT & DP w/SMPTE to fix analog transfer? | jibberia | Pro Tools TDM Systems (Mac) | 3 | 01-12-2005 08:56 AM |
Quick Time Transfer Problem to pc from Protools | audio1420 | Pro Tools TDM Systems (Mac) | 3 | 04-23-2003 09:31 AM |
Apogee or 888 to transfer analog into PT? | JimmyJangle | Tips & Tricks | 3 | 08-25-2000 10:46 PM |
