Old 02-22-2018, 01:56 PM
gcasper gcasper is offline
Default PT 2018 leaving Digi 002r locked up
Just installed 2018.1.0 last night. I'm using a Digi 002r for my interface and noticed that when I exit Pro Tools, it leaves the Digi 002r locked up. The sample rate light stays lit, but the 1394 status light goes dark and stays dark, meaning (I believe) somehow the firewire connection has been lost. If I power down the 002r and then power it back up, I can use it again, but if I don't, and I try to get back into ProTools, it doesn't see the 002r and uses ASIO4ALL as the interface.
Anyone have any idea what's going on here? Am I missing a setting somewhere to have the system release the 002r when ProTools shuts down, or is this a driver issue?
Ryzen 7 5800X, ASUS TUF Gaming x570-PLUS (WIFI) motherboard, 32gB 3200mhz memory, Windows 11 Pro, Focusrite 18i20, Raven Mti2, Protools Studio 2023.12.1
Old 02-22-2018, 03:14 PM
Default Re: PT 2018 leaving Digi 002r locked up
Some things to consider:
1-ASIO4ALL is a "last-ditch" driver and probably should NOT be used or installed(unless you have a real need for it).
2-002 is unsupported so nobody knows when it will simply no longer work with new PT software.
3-assuming you are on a PC, make sure(in Sound>Properties) that Windows is NOT using the 002 as its "default playback device"
Old 02-23-2018, 01:38 PM
Hey Dave:
Yes, I had only installed ASIO4ALL to troubleshoot an issue I was having with the Raven software on PT11/12.
And I don't have the 002r set as the default playback device. This is something new with 2018. I never used PT12, but neither 10 nor 11 did this, so...
Old 02-23-2018, 02:27 PM
Wizzoboy's Avatar
Wizzoboy Wizzoboy is offline
Nothing new about setting your PT interface to not be used by Windows. It has always caused problems because Windows likes to grab the interface for itself, setting the sample rate, and excluding PT.
Dell Precision 490 Workstation, dual 4 core 5355 Xeon, 16gb Samsung DDR2 ECC Ram - Windows 7 Ultimate - Nvidia GTX 650 - 3 x Internal WD Blacks - PT 2018.3 - Digi 002R - Original Mackie HUI - 3 screens - JBL Monitoring.
Dell XPS 8700 i7-4790 - 24gb RAM - Windows 10 - Nvidia GTX 1060 6GB with Studio driver 546.01 - 2 x Internal Samsung 860 EVO SSDs, and MSATA card - Davinci Resolve Studio 18.6.4 - 3 screens - Blackmagic Speed Editor - MK1 Presonus Faderport - Canon C100 mk2 - Atomos Ninja 2 - Zoom H2n
Old 02-26-2018, 02:41 PM
Wizzo... I understand it's not new to keep Windows from using an interface. What I meant was new was that ProTools 2018 is locking up my interface on exit, where PT10 and 11 did not.
Old 02-27-2018, 12:08 PM
daeron80 daeron80 is offline
It could be that the 1394 circuit in the 002R is failing, or that the one in your computer is failing, or some of each. But most likely, it's just that the 00x series is too far out of date to work properly with PT anymore.
David J. Finnamore
Old 02-27-2018, 02:42 PM
sleepingtiger sleepingtiger is online now
FWIW, I'm using an 002R in my home setup with 2018.1 HD and it works fine here with up to date Windows 10.
Pro Tools Ultimate 2024.3.1
Dell 7820 - dual Xeon 6132
64 gigs of RAM
Windows 11 Pro for workstations
HD Native PCIe
Lynx Aurora with LT-HD
Apogee
Mytek
Old 03-24-2018, 01:15 PM
gspointer gspointer is offline
not sure this is helpful-i'm on mac os 10.13.3
but my digi 002 (console) was not recognized by 2018.1 but is working great with 2018.3
actually it's more stable and more useful than it's been since PT10. also working great with FCPX which it wouldn't do before
cheers and good luck
Xpand!2 2018 & Air Instruments 2018 lgreen100 Pro Tools 2018 16 02-15-2018 05:01 PM
External Clock Locked? 002R/PT12/Win10 zolko 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 10-05-2016 08:02 AM
Can't get locked digi to enter record with PT HD senorsensor Post - Surround - Video 5 09-15-2008 02:53 AM
leaving your 002R on all the time? highdefhome Tips & Tricks 0 07-11-2004 03:23 PM
Digi 002 Control locked up after WinXIP crash Ryan Cox 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 02-12-2004 01:00 PM
