Old 07-03-2017, 11:38 AM
alejocazu alejocazu is offline
Default PT 12.8 Bug - Layered Editing doesn't turn off
Hello.
Pro Tools 12.8 doesn't disable 'layered editing' regardless of the button (located under the pencil tool) being off.
In other words, with 'layered editing' on or off, dragging a clip on top of another clip and then deleting the dragged clip doesn't separate the latter - is this happening to someone else?
Time to go back to 12.6 I guess...
Edit: I'm in Windows 10, 32GB Ram, i7 with 512GB SSD.
Pro Tools 12.7 worked perfectly fine.
Old 07-03-2017, 12:32 PM
Default Re: PT 12.8 Bug - Layered Editing doesn't turn off.
Ok so I've been trying a few things:
Dragging a clip in the middle of another clip (and then deleting) will split the latter.
However, dragging a clip at the end of another clip (overlapping the last part including its end) will NOT trim the latter, once the dragged clip is deleted, the overlapped clip returns to its initial length.
Old 07-03-2017, 02:18 PM
Marco Bernardo's Avatar
Marco Bernardo Marco Bernardo is offline
I can't reproduce this error.
Check the video and see if I'm doing anything wrong
They layer editing seems ok to me.
Marco Bernardo
Dialog Editor, Sound Designer, Re-Recording mixer
nMacPro 6Core/D500/512GB/64Gb ram | PT HD 12 HDN Thunderbolt | HD OMNI | Avid Artist Mix | Novation Impulse 25 | Waves Mercury Native | Audioease All In Bundle | SoundToys | McDSP Classic Pack | DUY Overpack | Arturia Beatstep Pro
Old 07-04-2017, 12:47 AM
Well that's exactly what I mean - I can see it in your video, you see when you overlap the end (or beginning) of the clip and then remove the overlapping clip, the overlapped audio returns to its original length - i need it to stay trimmed.
Basically turning 'layered editing' off is NOT working to trim clips, only to separate them.
Old 07-04-2017, 03:27 PM
I've tried with 12.7.1 and the layer editing as the same behaviour.
It's a bug, 12.6.0 and 12.6.1 don't do this it started with 12.7.0
Nice catch.
Marco Bernardo
Old 08-31-2017, 03:43 AM
Farhoof's Avatar
Farhoof Farhoof is offline
PT 12.8.1 is showing the same behavior. However, I have tested this in 12.5.2, before layered editting was introduced, and it's doing the exact same thing. Putting a clip over the end of another clip doesn't trim the clip when removed, it's being restored to it's original length.
Maybe 12.6 is wrong and reverted in 12.7.
Old 10-26-2017, 01:37 PM
daeron80 daeron80 is offline
It's driving me crazy because Shuffle mode doesn't work right with Layered editing turned on. Since it's no longer possible to turn it off, I have to use all kinds of weird tricks and workarounds to get edited clips to shuffle properly. Real pain. Almost enough to drive me to revert to PT11.
David J. Finnamore
PT 2023.12 Ultimate | Clarett+ 8Pre | macOS 13.6.3 on a MacBook Pro M1 Max
PT 2023.12 | Saffire Pro 40 | Win10 latest, HP Z440 64GB
Old 10-26-2017, 04:14 PM
TrentWilliams TrentWilliams is offline
Layered editing working fine over here .. specs in signature.
https://streamable.com/y4kqz
Pro Tools 2024.3.0|Perpetual • MTRX Studio • HDX1 • Sync-X • S3 • DockMac Mini 2018 - 3.2GHz i7 6-core macOS 13.6 • RAM 64GB DDR4 GPU AMD 6900XT 16GB • Monitor LG 32UL950-W
Old 10-27-2017, 06:04 AM
Thanks for that video example Trent. Mine works correctly in simple situations like that, as well. But real-world edits are a mess. So I need to correct my description. Turning Layered editing on and off does make a difference. But Shuffle mode gets messed up by layers whether it's on or off. This does change the nature of my pending Ideascale post. Instead of reporting it as a bug, I will request that Shuffle mode editing work the way it did before layers were a thing.
May I ask what you used for video screen capture?
David J. Finnamore
Old 10-27-2017, 04:02 PM
Can you make a video to show how you "like" it to use before the layering was introduce?
You can use Quicktime X to screen capture. Just go to file and the options is there.
Thanks.
Marco Bernardo
Layered Editing Bug in Warp mode loopzilla2 Pro Tools 12 2 12-13-2016 11:17 AM
12.6 Layered Editing? ptfigg Pro Tools 12 6 11-30-2016 10:58 PM
12.6 layered editing not what it should be pyrmont25 Pro Tools 12 8 09-29-2016 03:02 PM
Mbox Pro 3 doesn't turn on! Mesih FireWire & USB Audio Interfaces (Win) 3 06-12-2014 03:12 PM
If my Mac DOESN'T TURN OFF ?? hed 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 08-08-2005 11:40 PM
