S6 not recognizing any modules, including master module
EDIT: big brain fart. all fixed.
Re: S6 not recognizing any modules, including master module
Which ethernet port on the MTM is connected to the switch? Port 2 is the go.
OK, I figured it out.. Misread the instructions.. Everything goes to the switch and then a cable from the switch goes to the computer, that's what I need to do.
Change it up. Connect Port 2 on the MTM to the S6 internal switch. Then from the internal switch, run that out to your computer or external switch.
Sounds as though the MTM is not seeing the rest of the networked modules. |
Yup
Master Module FAN NOISE | rcutz | Avid S4/S6 | 11 | 07-29-2015 06:39 AM |
Setting up Master Keyboard with Modules | BTyler1230 | Pro Tools 11 | 2 | 04-02-2014 05:51 AM |
Hd 10 including ilok | vin7 | Buy & Sell | 2 | 03-23-2013 12:37 PM |
10.3 upgrade including IEP | Righty27 | macOS | 4 | 09-22-2012 04:50 AM |
2 Problems: PT not recognizing plug-in and CPU not recognizing external hard drives | jasonguitar | Pro Tools M-Powered (Win) | 0 | 06-28-2009 06:32 AM |
