Convert session from 44.1 to 48 k ?
Hi, i have to mix the song of a friend recorded with mbox 2 mini in 24 bit/44.1 k format.
He want the final mix in 24 bit/48 k format, im not sure what is best to get the better quality since im really not a pro. - Use the Save copy in ... command to convert the session in 24 bit/48 k - Mix the song in 24 bit/44.1 k and just bounce to disk in 24 bit/48 k - Mix and Bounce in the original format to have no quality loss. Thanks |
Re: Convert session from 44.1 to 48 k ?
number of ways to do this but here's what I think is one of the easiest / best ones :
- Create new session at 48/24 - import session data from the 44.1/24 session and convert / copy on import clean hassle-less way to create separate folders where you keep things separated from each other. Chris
Chris Lambrechts Applications Specialist- Live Sound |
So the files are not really losing quality when doing convertion, right ?
Thanks for help and tips |
The benefit of up-converting before you start mixing (vs. up-converting when you bounce to disk) is that mix and plugin processing happens at this higher clock rate and should produce less artifacts. At least that is the idea. Darryl |
Thanks for the info, simple and clear now.
Help? Can Anyone convert a ptx session to ptf for me?? | kebulan | Pro Tools 10 | 2 | 04-24-2012 04:37 PM |
Way to Convert Session Bit/Sample Rate??? From Within Session??? | Table Syrup Records | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 10-25-2011 09:48 AM |
How do I convert a PT session from SD2 to Wav? | myfavedave | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 06-08-2008 12:24 PM |
Convert Mac session to PC... | bigbottombass | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 08-07-2005 04:13 PM |
What's the best way to convert a 48k session to 44k ??? | dw | Tips & Tricks | 4 | 03-13-2000 07:57 PM |
