Old 10-22-2010, 05:23 PM
NickPt NickPt is offline
Default Please help - "Problem detected with audio clock" error on HP laptop
Hey everyone,
I have an MBox 2 hook up via the USB port running Pro Tools LE on my HP Pavilion dv6 laptop. Everything seems to be installed correctly but when I hit record I get this error:
"Problem detected with audio clock. Check that your clock source and sample rate are correct."
I am aware that I need to be saving to an external harddrive and I'm going to go and get one but could there be anything else about this set up that is causing the problem (I've read about this problem still happening after people have external harddrives)? I'm very much a novice to this stuff so details would be sweet as i might not understand otherwise!
Thanks heaps in advance for your help. Here's my Sandra report:
Processor
Model : Intel(R) Core(TM) i7 CPU Q 720 @ 1.60GHz
Speed : 1.73GHz
Cores per Processor : 4 Unit(s)
Threads per Core : 2 Unit(s)
Type : Mobile, Quad-Core
Integrated Data Cache : 4x 32kB, Synchronous, Write-Thru, 8-way, 64 byte line size, 2 threads sharing
L2 On-board Cache : 4x 256kB, ECC, Synchronous, ATC, 8-way, 64 byte line size, 2 threads sharing
L3 On-board Cache : 6MB, ECC, Synchronous, ATC, 12-way, Exclusive, 64 byte line size, 8 threads sharing
Computer
Platform Compliance : Intel Centrino Mobile Technology
Mainboard : HP 1448
BIOS : HP F.05 04/15/2010
Bus(es) : PCI PCIe IMB USB i2c/SMBus
Multi-Processor (MP) Support : No
Multi-Processor Advanced PIC (APIC) : Yes
Total Memory : 8GB DDR3 SO-DIMM
Chipset
Model : HP Clarksfield/Lynnfield DMI
Front Side Bus Speed : 2x 2.4GHz (4.79GHz)
Chipset
Model : HP Core Mobile (Clarksfield) UnCore
Front Side Bus Speed : 2x 2.13GHz (4.26GHz)
Channels : 2
Memory Bus Speed : 2x 665MHz (1.33GHz)
Memory Module(s)
Memory Module : Samsung M471B5273BH1-CH9 4GB DDR3 SO-DIMM PC3-10700S DDR3-1334 (9-9-9-25 4-34-10-5)
Video System
Video Adapter : ATI Mobility Radeon HD 5650 (400 SM5.0 550MHz, 1GB DDR3 2x800MHz, PCIe 2.00 x16)
Graphics Processor
STREAM Processor : ATI Mobility Radeon HD 5650 (400SP 5C 550MHz, 1GB 2x800MHz)
Compute Shader Processor : ATI Mobility Radeon HD 5650 (400SP 550MHz, 1012MB 2x800MHz)
Storage Devices
SAMSUNG HM641JI (640.1GB, SATA300, 2.5", 5400rpm, NCQ, 8MB Cache) : 596GB (C:) (D:) (E:)
hp BD-ROM BC-5501H (SATA150, BD-R, DVD+-RW, CD-RW, 2MB Cache) : N/A (F:)
Logical Storage Devices
SYSTEM : 199MB (NTFS)
Hard Disk (C:) : 575GB (NTFS) @ SAMSUNG HM641JI (640.1GB, SATA300, 2.5", 5400rpm, NCQ, 8MB Cache)
RECOVERY (D:) : 21GB (NTFS) @ SAMSUNG HM641JI (640.1GB, SATA300, 2.5", 5400rpm, NCQ, 8MB Cache)
HP_TOOLS (E:) : 99MB (FAT32) @ SAMSUNG HM641JI (640.1GB, SATA300, 2.5", 5400rpm, NCQ, 8MB Cache)
Optical Drive (F:) : N/A @ hp BD-ROM BC-5501H (SATA150, BD-R, DVD+-RW, CD-RW, 2MB Cache)
Peripherals
LPC Hub Controller 1 : HP HM55 LPC Interface Controller
Audio Device : HP P55/PM55/3400 High Definition Audio
Audio Device : HP Redwood HDMI Audio [Radeon HD 5600 Series]
Disk Controller : HP P55/PM55/3400 4 port SATA AHCI Controller
USB Controller 1 : HP P55/PM55/3400 USB2 Enhanced Host Controller
USB Controller 2 : HP P55/PM55/3400 USB2 Enhanced Host Controller
SMBus/i2c Controller 1 : Intel 801xx/63xx SMBus
Network Services
Network Adapter : Bluetooth Device (Personal Area Network)
Wireless Adapter 1 : Atheros AR9285 802.11b/g/n WiFi Adapter (802.11g (ERP), AES-CCMP, 54Mbps)
Operating System
Windows System : Microsoft Windows 7 Home 6.01.7600
Platform Compliance : x64
Windows Experience Index
Current System : 5.9
Old 10-22-2010, 09:30 PM
Default Re: Please help - "Problem detected with audio clock" error on HP laptop
Start by disabling wifi and bluetooth when running Pro Tools. When it comes to an external recording drive, don't buy just any drive. You need to meet certain requirements. No USB drives, firewire drives need to use an Oxford 9xx chipset(Glyph and OWC Mercury drives do). The drive must be 7200 rpm (or faster) and no "green" drives(you don't want some power management BS spinning down the drive while recording). eSATA drives are not tested/supported, but many are using them with good performance. If you need a firewire port, get an approved card that fits your laptop slot(assuming it has one). The SIIG brand seems to be the better choice there. You might be able to record a few tracks to the internal drive, but don't expect much(its a 5400 rpm drive so performance will be poor at best). Also, you MUST set power options correctly. That means no screen saver, drives never sleep, screen stays on and USB ports need to have power management turned off(so they always stay powered). You may also get better performance by changing to another USB port(once you find one that works good, always use that one).
Old 10-25-2010, 12:59 PM
dolbydog dolbydog is offline
If you don't have it yet, the 8.0.4 update solved this problem for me.
Old 10-25-2010, 01:31 PM
For sure on this. And get the cs2 update as it fixes a serious audio placement problem that comes with 8.0.4
Old 12-17-2010, 04:46 PM
foulkown foulkown is offline
..After 4 motnhs of recording and getting this "problem decteced with audio clock" i am fustrated when this happenes when i have an artisit in my studio and i cant record, and have to restart, sometimes it works sometimes not.
Id really like to get to the bottom of this please help !
sometimes after the dialog of the audio clock problem, i press play and i get craks and pops like on 8.04cs2
IM ON 8.03
.::My PC::.
SiSoftware Sandra
Computer
Model : Asus N61Jq
Workgroup : WORKGROUP
Host Name : Daigoson
User : Foulkown
Processor
Speed : 1.73GHz
Computer
Mainboard : Asus N61Jq
BIOS : AMI N61Jq.210 05/19/2010
Total Memory : 4GB DDR3 SO-DIMM
Chipset
Model : ASUS Clarksfield/Lynnfield DMI
Chipset
Model : Intel Core Mobile (Clarksfield) UnCore
Channels : 2
Memory Bus Speed : 2x 532MHz (1GHz)
Memory Module(s)
Memory Module : Hynix (Hyundai) HMT125S6BFR8C-G7 2GB DDR3 SO-DIMM PC3-8500S DDR3-1066 (7-7-7-20 4-27-8-4)
Video System
Video Adapter : ATI Mobility Radeon HD 5730 (400 SM5.0 650MHz, 1GB DDR3 2x800MHz, PCIe 2.00 x16)
Graphics Processor
STREAM Processor : ATI Mobility Radeon HD 5730 (400SP 5C 650MHz, 1GB 2x800MHz)
Compute Shader Processor : ATI Mobility Radeon HD 5730 (400SP 650MHz, 1014.5MB 2x800MHz)
Storage Devices
Seagate ST9320423AS (320GB, SATA300, 2.5", 7200rpm, NCQ, 16MB Cache) : 298GB (C:)
Seagate ST31000528AS (1TB, USB/SATA, 3.5") : 932GB (F:)
MAT[bleep][bleep][bleep][bleep]ADVD-RAM UJ890AS (SATA150, DVD+-RW, CD-RW, 1MB Cache) : N/A (E:)
OS (C:) : 75GB (NTFS) @ Seagate ST9320423AS (320GB, SATA300, 2.5", 7200rpm, NCQ, 16MB Cache)
Iomega HDD (F:) : 932GB (NTFS) @ Seagate ST31000528AS (1TB, USB/SATA, 3.5")
Optical Drive (E:) : N/A @ MAT[bleep][bleep][bleep][bleep]ADVD-RAM UJ890AS (SATA150, DVD+-RW, CD-RW, 1MB Cache)
Peripherals
LPC Hub Controller 1 : ASUS HM55 LPC Interface Controller
Audio Device : ASUS P55/PM55/3400 High Definition Audio
Audio Codec : Realtek Semiconductor High Definition Audio
Audio Device : ASUS Redwood HDMI Audio [Radeon HD 5600 Series]
Audio Codec : ATI (AMD) HDMI Audio
Disk Controller : ASUS P55/PM55/3400 4 port SATA AHCI Controller
USB Controller 1 : ASUS P55/PM55/3400 USB2 Enhanced Host Controller
USB Controller 2 : ASUS P55/PM55/3400 USB2 Enhanced Host Controller
USB Controller 3 : ASUS uPD720200 USB 3.0 Controller
Printers and Faxes
Printer : Microsoft XPS Document Writer (600x600, Colour)
Network Services
Network Adapter : Atheros AR8131 PCI-E Gigabit Ethernet Controller (NDIS 6.20)
Wireless Adapter 1 : Atheros AR9285 Wireless Network Adapter (802.11g (ERP), 54Mbps)
Power Management
Mains (AC) Line Status : On-Line
Battery No 1 : 98%
Operating System
thank you for your time to read this..
JAH BLESS
Edit/Delete Message
Old 06-28-2011, 05:49 PM
:bump:
"Problem detected with audio clock. Check audio clock and sample rate." Focusrite 2i4 Terry Wetzel Third Party Interfaces 10 11-08-2013 06:18 AM
"problem detected with audio clock" error turbodude Pro Tools M-Powered (Win) 0 03-10-2011 01:01 PM
"Problem with audio clock detected." error; Pro Tools won't start playback wintersdark 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 07-04-2010 06:23 PM
"Problem detected with audio clock" on brand new installation Katzi 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 06-18-2010 12:10 PM
Error: "Problem detected with audio clock. Check that your clock source and sample... mongo_man 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 28 05-01-2010 06:08 AM
