Old 06-15-2010, 11:57 PM
Katzi Katzi is offline
Default "Problem detected with audio clock" on brand new installation
I just bought an Mbox 2 mini with PT LE. I had som etrouble installing, but it looks like it went through finally. But both after the fresh install and after installing the 8.0.3 update, I get rhis message when trying to play back.
"Problem detected with audio clock. Check that your clock source and sample rate are correct".
I wonder if it is related to a bad install or if I can correct it. Can't seem to locate where. Anybody who knows what I can do? Thanks.
Kat
Old 06-16-2010, 10:14 AM
cwsand's Avatar
cwsand cwsand is offline
Default Re: "Problem detected with audio clock" on brand new installation
Go to the menus in ProTools and look under Session - check the sample rate and bit rate used in your session. Then go back to the menus and check Hardware - make sure the sample rate and bit rates are the same as your session.
Help Us Help You
Chris
__________________________________________________
Focusrite Liquid Saffire 56
TCE Studio Konnekt 48
PreSonus Digimax LT
Gigabyte GA-Z170-HD3P / i7 6700K 4.1 GHz / 32GB Crucial DDR4
macOS High Sierra Version 10.13.6
Pro Tools HD 2020.5
Old 06-17-2010, 03:37 AM
Thanks
Both are set to 44.1 kHz, I'm afraid... Anyone else with this problem?
Old 06-17-2010, 04:38 AM
TCM's Avatar
TCM TCM is offline
Check if your driver for the Mbox is ok.
002R BLA mod and Mbox mini 2, PT 11.3.2,
HD Native, HD IO 16x8x8, PT 2018.7, Win 10 Pro 64, Asrock X99 Extreme6/3.1, i7-6850K, 32 GB Ram, SSD system drive, ssd audio drive
Old 06-17-2010, 07:42 PM
TylerW TylerW is offline
I am having the same problem, I haven't figured out a solution yet.
Usually that will happen and I'll restart the computer and it will work fine.
Old 06-18-2010, 12:10 PM
sonicapg sonicapg is offline
Originally Posted by Katzi View Post
Thanks
Have you made the optimizations for your operating system?
I higlly recommend to do them all.
"Problem detected with audio clock. Check audio clock and sample rate." Focusrite 2i4 Terry Wetzel Third Party Interfaces 10 11-08-2013 06:18 AM
Please help - "Problem detected with audio clock" error on HP laptop NickPt 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 06-28-2011 05:49 PM
"problem detected with audio clock" error turbodude Pro Tools M-Powered (Win) 0 03-10-2011 01:01 PM
"Problem detected with audio clock..." valentin.meys 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 11-12-2010 11:23 AM
"Problem with audio clock detected." error; Pro Tools won't start playback wintersdark 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 07-04-2010 06:23 PM
