Old 04-06-2018, 12:41 AM
lapieuvre lapieuvre is offline
Default Audio files deactivated when opening pt 5 files
Hi, I tried to open a pt 5 session. The audio files are in SD2 format (Sound Designer 2) and in pt 12.7, the audio doesn't playback, and i also don't see the waveform image in the tracks.
Is there a way to convert pt 5 files into pt 12?
Thanks
Envoyé de mon iPad en utilisant Tapatalk
__________________________
MBP 2015, 2.8 GHz Intel Core i7, OSX 10.10.5, 16 gigs Ram,
Old 04-06-2018, 12:46 AM
Drew Mazurek's Avatar
Default Re: Audio files deactivated when opening pt 5 files
Thanks
Quickest way to make this happen is to open with PT10.
www.drewmazurek.com
Old 04-06-2018, 10:14 AM
The Weed's Avatar
The Weed The Weed is offline
This ^^^^ because, after PT 10, PT won't open SD2 files.
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
usaved PT session saving unsaved audio files to audio files folder mermermer Pro Tools HDX & HD Native Systems (Mac) 1 07-18-2012 11:50 AM
Audio files on one FW Drive render blank audio files when copied ridmik Digidesign Hardware & Software 4 03-30-2012 12:55 PM
Opening Mac audio files on my pro tools pc. JOHN9 Pro Tools TDM Systems (Win) 2 11-15-2005 07:17 AM
opening pt audio files in other apps? bH101 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 08-19-2004 09:28 AM
trouble opening session: can't locate audio files eddie v Pro Tools TDM Systems (Mac) 1 10-31-2003 09:44 AM
