Old 01-06-2014, 03:51 AM
Detlef Brockmann Detlef Brockmann is offline
Default Pro Tools 11.1 gives me this during startup
Could not complete your request because You do not have appropriate access privileges (13) while creating "cy" while creating "fyg5_lx55n95c0z247v12b940000gn" while creating "T" while creating "AAX" while creating "Plug-In Settings".
and then freezes with "Initializing Controllers".
Any idea?
OSX 10.8.5
Old 01-06-2014, 04:43 AM
Hanswurstlsepp Hanswurstlsepp is offline
Default Re: Pro Tools 11.1 gives me this during startup
Any idea?
OSX 10.8.5
My first idea is: Repair disc permissions.
If this doesn't help post back here
Cheers, STeff
MacPro5,1 , 32 Gig Ram, 2xATI Radeon HD 5770, OSX10.13.2  Pro Tools|HDX Ultimate 2018.4.0  HD I/O&192Digital&96&96i I/Os  D-Command ES  4xUnitor8 & 2xAMT8
Old 01-06-2014, 04:45 AM
I have tried that a couple of times. Nothing has changed.
Pro Tools 11.0.2 has been working fine.
Any other idea?
Cheers, Detlef.
Old 01-06-2014, 04:46 AM
Any other idea?
Cheers, Detlef.
Could be a problem of a specific PlugIn ... but I doubt.
I would de-install PT and re-install it.
Edit: And of course trash PT prefs and databases etc.
Cheers, STeff
Old 01-06-2014, 08:01 AM
found the solution: I had two drives with the same name.
Cheers, Detlef.
Old 01-06-2014, 08:10 AM
Cheers, Detlef.
Strange nevertheless that PT 11.1 had problems and 11.0.2 was running fine. I guess u used the same (system) drive ?
But good you found it !
Cheers, STeff
Old 01-06-2014, 10:19 AM
Yes, Pro Tools 11.0.2 was running on the same drive. But that was not the problem. The problem was the other system drive (OSX 10.6, PT 9.0.6) with the same name.
I guess Pro Tools 11.1 was trying to access that system drive.
Thanks for your help anyway.
Cheers, Detlef.
Pro Tools HD 7.3.1 crush on startup Nikis macOS 15 01-13-2014 03:13 AM
Pro Tools 9.0.5 crashing just after startup ARTHANOR Productions macOS 16 11-24-2011 07:30 PM
Pro Tools LE startup error WindyCityUSA 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 08-04-2011 11:33 AM
Pro Tools won't startup stevieray2305 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 13 02-23-2010 03:54 PM
Pro Tools crashing at startup Jóhannes Bjarnason 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 12-10-2006 06:04 AM
