Old 02-17-2020, 09:26 AM
rmccam rmccam is offline
Default Pro Tools 2019.12 Ultimate Crashes 2019 Mac Pro
I'm in that unfortunately predicament where I had upgrade my computer, so now I have a new 2019 Mac Pro, running Catalina OS 10.15.3, with Pro Tools 2019.12 installed. I have an HDX card but I haven't installed it yet because I thought to test it native first. It's been a bit of a disaster.
PT launches Ultimate, because that's my license, and it goes through the long process of scanning the plugins. I've been using PT long enough to know to trash prefs and that you may have a sour plugin and to just pull it out of the Plug-Ins folder, but I'm getting crashes from lots of stuff that I know is supported: Waves v11, Izotope (sorta supported), but most confusing is VariFi – which I gather PT won't run without because it keeps reinstalling into the Plug-Ins folder. It's all very odd.
I am well aware that my system isn't supported so I don't expect a solution, per se, but I was just wondering if anyone else has had this issue, because I know some people have got it up and running without any issues.
Thanks in advance.
Ryan
Ryan McCambridge
Writer - Producer - Engineer
Old 02-17-2020, 10:20 AM
Meads Meads is offline
Default Re: Pro Tools 2019.12 Ultimate Crashes 2019 Mac Pro
I can't provide any personal experience as I don't have one of those machines, just the usual questionnaire.
Did you set the MacPro up from scratch or did you migrate a backup?
I'd suggest you create a new user account and see if PT runs without hiccup from there. If so, there's gotta be something garbled up in the system files of your original user account.
iMac Pro
- MacOS 10.14.6
- Pro Tools U HDN 2019.6
- Avid HD Omni + HD I/O 8x8x8
- C|24 | S3 | Dock
Old 02-17-2020, 10:21 AM
johnnyv johnnyv is offline
Why don't you install your HDX card? Everyone I've seen on the DUC and Gearslutz is working fine, including me.
Old 02-17-2020, 10:26 AM
Thanks for the replies.
Meads – Shockingly, it's a completely fresh install. I did that specifically to have a nice, clean new system.
johnnyv – I'm going to try that today. I've been trying to close out a job from my laptop running a Sonnet chassis. I was hoping not to disturb the equilibrium there and thought that running it native would prove to be LESS of a hassle, given that it's actually supposed to be supported. I'll report back after I try it though.
Ryan McCambridge
Old 02-17-2020, 10:35 AM
JFreak JFreak is online now
2019 Mac Pro is still unsupported, have to wait until 2020.x release. Until that you are on your own. Some say switching to another slot helps.
Old 02-17-2020, 11:16 AM
Southsidemusic's Avatar
We have the first HDX card in slot 6 and works great. New 28core 384 GB ram and loads of SSD space. Try that slot and see what happens.
Best Regards
Christopher
South Side Music Group
WEBHOME
Old 02-17-2020, 03:36 PM
Well, here's the update for posterity more so than anything else.
1) I trashed PT and reinstalled it without any other plugins. It seemingly worked great.
2) I installed the HD Driver and the HDX card, first in slot 6 then in slot 5, and the Mac didn't recognize it. Oddly though, when I booted up the Mac Pro, I could hear the HDX card's fan cycle, the way it does on boot up. But when I run DigiTest, nothin.
3) Everyone had been talking about the "Belkin Aux Power Cable Kit for Mac Pro", and to use the "Cable Set 3 PCIe Aux Power Cable 6-pin to 6-pin", which I bought and used (which obviously didn't work). However, in the cable that came with my HDX card, there's a cable that has the same connectors. I tried it as well (which also didn't work), but it connected fine. Here are some photos:
Large end:
Small end:
Motherboard to first cable (the one that's the same as the Belkin):
First cable to the harness of the second cable:
Second cable connected to the HDX card:
Am I crazy? Did I miss something? Is there a reason I'd need the Belkin cable?
Back to my issue...
Again, Pro Tools is crashing on the plugins launching but it's never the same plugins that cause it to crash. It's been Trim Ha Ha! VariFi and Izotope are culprits as well. I don't suspect that it's any one plugin though, it's some bigger.
I also think that everyone who has this up and running is on OS 10.15.2, right? It might be something with OS 10.15.3. Either way, it's been a very unproductive day.
Thanks again everyone.
Ryan
Ryan McCambridge
Old 02-18-2020, 03:07 AM
peterle peterle is offline
bad ram?
try swapping ram modules.
foley artist , soundeditor
Old 02-18-2020, 03:08 AM
iZotope is a notorious crasher and Dfi plugins too. Nothing to worry about hardware-wise
Old 02-18-2020, 12:45 PM
I did a memory test this morning anyway but that’s not the issue. Thank you though.
Ryan McCambridge
FS : Pro Tools Ultimate 2019.12 + Digilink I/O Gemylon Buy & Sell 5 03-02-2020 12:08 PM
003 console with Pro Tools Ultimate 2019 on a Mac? EricRobinson Pro Tools 2019 3 01-12-2020 10:42 PM
003 console with Pro Tools Ultimate 2019 on Mac EricRobinson 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 01-11-2020 03:11 PM
Pro Tools Ultimate 2019 Perpetual License + THEMAGICIAN Buy & Sell 0 07-20-2019 04:02 PM
Pro Tools Ultimate 2019.5 and HDX Avid Technical Alerts 0 05-09-2019 01:55 PM
