Old 10-23-1999, 11:22 AM
pyro pyro is offline
Default how to thow away plugins on old session?
I have an old session that has bugs in the plug ins. Problem has been solved but old sessions wont open. when I try to throw away plug in folder within old session folder it auto-rebuildes it self. does anyone know how to loose the plugs that are on the old session BEFORE I open it. Im just after the raw tracks and cant import into new session because they are edited and are not continous files need to open session to finish an album(cd).When I try to open session I get type 3 and type 2 errors?????? only need raw tracks but cant get folder to open ....Help>>>>>>>>>>>>>>>>>>>!!!!!!!!!
Old 10-23-1999, 06:46 PM
ppine ppine is offline
Default Re: how to thow away plugins on old session?
Reboot:
Then remove the actual offending plug from the DAE folder, plug-ins, (drag it to the desktop) then open session. Pro Tools will tell you "Could not create plug in blah blah".
Session will open, without that plug!
best of luck!
Old 10-24-1999, 09:05 AM
PPINE....THANKS
Old 10-24-1999, 10:11 AM
32 bit session using 24 bit plugins remusjacobs Pro Tools 10 1 02-14-2012 09:10 PM
unwanted distrocion even thow im only using midi musicdanz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 02-04-2011 06:39 AM
From a TDM/HD system to LE plugins, can any one look at my session? 68topls 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 10-20-2009 06:03 PM
how do i copy plugins from one session to another? maskedman72 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 11 04-05-2004 12:58 PM
more plugins at 16 or 24 bit session? gigi 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 10-22-2000 09:59 AM
