A Big Problem in my Score Editor
I have a question that seems stupid but I can't solve it... How can I write correctly with musical notation in Score Edior this figure (1/16 notes 1/16 Rest 1/16 note 1/16 rest)? When i write these notes, i have ( 1/8 note 1/16 note 1/16 rest ) To more clarify this problem Suppose i have this figure [( 1 2 3 4 ) note] and every note is equal to 1/16 note if i clear (note N°2) the note N° 1 becomes (1/8 note) than if i clear note N°4 the "note N°3" becomes (1/8 note) so finally i have 1/8+1/8 note and the rests disappear The midi notes in midi editor are correct but in score editor are not correct it's a bug in Pro tools??...how can i solve this problem, this is really my big problem because i use score editor most of time. i upload a photo to clarify my problem ( i use Pro tools HD 10.3.0 / Win 8 64bits ) Thank you so Much Last edited by hangar79; 04-23-2013 at 04:45 PM. |
Re: A Big Problem in my Score Editor
Hi !!!
i Find the Solution: 1 / Open "midi Editor" 2 / Write the 1/16 notes and 1/16 rests that you want Now we will adjust the notes: 3 / Open "Real Time Duration" 4 / Open the "Duration" panel" (it is between "Quantize" and "Delay") , ...... In The duration panel it there's 3 buttons "duration Mode" / "Duration amount" / and "Duration Units" 4 / in "Duration Amount" Put the value "2" so that it appears 2l000 ticks " 5/ in duration Panel go to "Duration Mode" and change it to "Subtract" 6 / Now enable the Duration button (its color changes to green) 7 / Finally "Write to Track" and everything is stored ... 8/ If there is no sound Open "Event Properties" ....choose "Set to all" than put a number between 0.000 and 0.048 DONE Last edited by hangar79; 04-24-2013 at 05:38 AM. |
Thank you for Help
Score Editor problem in 8.0.3 | pogmoor | Pro Tools M-Powered (Mac) | 0 | 02-14-2010 01:58 PM |
Score Editor Bug? | Maars | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 09-21-2009 03:43 PM |
Score editor problem | DonaldM | Tips & Tricks | 3 | 07-08-2009 04:26 PM |
Score Editor Note Problem | andyj4308 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 06-30-2009 11:35 AM |
NEW Score Editor in PT | Tamer Ciray | General Discussion | 22 | 08-06-2002 11:28 PM |
