#31
Re: Magma PCI Expansion Alternative?
Speaking of ATX kits -- I stumbled into this... about $1000 savings, less the cost of the ATX case and power supply...
http://www.bhphotovideo.com/c/produc...xpress_to.html Is the PE6NE identical to the PE6R4, less the case? Penny wise/Pound foolish?
--Jeremy |
#32
#33
Yup exactly the same, there is an option to buy the PSU as well, can anyone chime in on cheaper 500W PSU's? Surely there a lot more 4 LESS
Anyone got chassis ideas as well? Been looking at various PC full cases, much cheaper
HD 3 Accel PCI HP XW9300 192 I/O Midi I/O |
#34
You DON'T need the latest and greatest i7 compatible power supply for this... a sub-$100 PSU will be more than adequate -- the reason I like Enermax is the fan is varispeed, and essentially the size of the unit. VERY quiet. $50 after rebate. I have one Enermax PSU that has been in service 24/7 for 5 years. I am sure there are other brands that are as good. This is one option.
--Jeremy |
#35
When the 24 Core (12 Cores with Hyper Threading) Mac Pros come out in May/June
You will not need an expansion chassis. |
#36
Hi Jeremy, so you are using the enermax psu with this magma mainboard?
#37
Why will they be PCI again
#38
no, with my other PCs I've built. Only one of this model, other mobos required slightly different models. I'm just saying that a good PSU is available for sub-$100
--Jeremy |
#39
You will unless Apple makes the case REALLY HUGE. You can only fit 3 other cards in there right now which, if you have an HD3 system, would leave you no room for anything else.
#40
cheers
Magma Or Digi PCI expansion? | louisenslinproduce | Pro Tools TDM Systems (Mac) | 6 | 01-25-2011 06:55 AM |
Has anyone switched from Expansion HD to the new Magma? | mixboy bob | Pro Tools TDM Systems (Mac) | 22 | 10-30-2007 05:44 PM |
MAGMA EXPANSION CHASSIS | studiojimi | Pro Tools TDM Systems (Mac) | 3 | 03-09-2007 07:40 PM |
Magma expansion on a a 15" or 17" PB G4, OSX, PT6? | tlester | Pro Tools TDM Systems (Mac) | 5 | 08-29-2003 12:46 PM |
Expansion Chassis Alternative? | cjguitar | Tips & Tricks | 1 | 05-02-2001 01:07 PM |
