Old 09-29-2015, 12:30 AM
BGMusic BGMusic is offline
Default Ilok 2 blue light flash of death
My Ilok2 is flashing it's blue light at me and when it does, my computer doesn't recognize it. When I put it in the freezer for a few minutes, it then works until I completely turn off the computer, then when I turn it back on, it flashes again. Is it about to die? Should I buy a new ilok2 and transfer the authorizations asap?
PT 10.3.10, 12.4, Logic Pro 9.1.8 Logic Pro X 10.1, Ableton Live 9, Studio One 3.x DP 9 Sibelius 8.5 OS 10.8.5 Mac Mini with Lion Server 2.0ghz quad I7 16 gbs ram, UAD Apollo Twin . PT Mix Plus PT 6.4.1 TDM Mac OS 10.3.9 G4 450 mhz 1 gb ram, Digi 882/20. And a bunch of hard drives.
Old 09-29-2015, 01:35 AM
nikhilmulay nikhilmulay is offline
Default Re: Ilok 2 blue light flash of death
If you are getting it back on for a few minutes, transfer all licences back to your account asap and get a new ilok.
If it's under warranty, send it back to pace and they should replace it for you.
Recommend you get ZDT. Worth the expense when something goes wrong.
Old 09-29-2015, 04:37 AM
Southsidemusic's Avatar
Oooooooo ... Get them licenses OFF that ilok A S A P!!! This happened to us a few weeks ago and as I was stupid enough to think " i yea, I'll get the licenses off later as we were using them and a few days later it stopped connecting all together and had to be scrapped.
Our ilok started blinking when connecting and it was hit and miss, sometimes it stopped blinking and just went dark, sometimes it flashed a few seconds, maybe 10-15 seconds then worked for an hour or less and after a few days of on and off it dies a horrid death
Thank GOD for ZDT and we were sorted but the stress was extremely daunting and not what we need trying to make music
Do the transfers and get a new ilok2 bedore it goes all dead.
PS. You can't get ZDT after the fact as it needs to be seen by Ilok Manager when buying ZDT and then there is a cooling off period so act now
Best Regards
Christopher
South Side Music Group
WEBHOME
Old 09-29-2015, 09:40 AM
skyko skyko is offline
Maybe I am paranoid, but I always keep a spare iLok around. So you may want to consider buying 2 iLoks to keep one spare.
Old 09-29-2015, 12:03 PM
DRC Music's Avatar
DRC Music DRC Music is offline
This! ^^^
• Pro Tools Ultimate 2019.12 • Logic X 10.4.8 • Studio One 4 Professional 4.6.0
• MacOS 10.15.3 • 2018 Mac Mini • 6 Core i7 @ 3.2Ghz • 32GB DDR4 • MOTU 828es
• VE Pro Server • MacOS 10.14.6 • 2010 Mac Pro • Dual 6 Core Xeon @ 3.33Ghz • 48GB DDR3
Old 09-29-2015, 01:19 PM
After purchasing another Ilok 2 and then de-installing and re-installing drivers and freezing the ilok and gingerly sliding it into the USB connector with no luck I just jammed something into the USB connector on the Ilok itself fiddled with it said a silent prayer slid it in and it's still working!!!! I've since moved all the licenses to the new ilok2. PHEW that was scary. But the old on of course is taunting me by continuing to work.
Old 10-01-2015, 06:05 PM
Update. Once I bought the new ilok crammed the string cutter into the USB connector on the end of the defective ilok and successfully got the licensed off of it, the old ilok now works solidly. The old previously malfunctioning ilok.
Old 10-02-2015, 10:42 AM
:Rob: :Rob: is offline
Mine started to acting weird and not working from time to time thankfully I was able to transfer all the licenses before it died, but I almost had an anxiety attack during the transfer process. :) Now I always keep a spare one in a drawer.
Old 10-06-2015, 06:32 PM
BrianJArmstrong BrianJArmstrong is offline
I have to ask... is putting it in the freezer a known fix for certain iLok issues, or is that just something you do with all your electronics when they're on the fritz?
MacBook Pro: Retina, 15", Mid 2014
Processor: 2.5 GHz Intel Core i7
Memory: 16GB 1600 MHz DDR3
OS: 10.12.5
PT: 12.8 HD - no interface. headphones and ilok.
Old 10-09-2015, 10:21 PM
Believe it or not, putting it in the freezer is a known temporary fix for the ilok. I discovered it on the internet of all places.
Blue Cat's PatchWork Updated to v1.62, with brand new Light Blue UI Theme bluecataudio AAX Plug-ins 5 01-10-2015 01:41 AM
Tap Tempo Light dont flash anymore Davoetta VENUE Live Sound Systems 12 11-13-2014 04:31 AM
New iLok flashing blue light teknisk.tvf@hil.no Pro Tools 9 0 08-03-2011 04:57 AM
blue screen flash and reboot after installation Rudy Michael 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 11-24-2005 09:19 AM
SSD..updated firmware, now light just flash, doesn't work!! HELP!! maxtraxstu Pro Tools TDM Systems (Mac) 6 01-18-2000 04:52 PM
