Old 03-24-2016, 10:01 PM
a1rflow a1rflow is offline
Default Allocating Video tracks to a different disk
Hi everyone -
Is there any way to allocate my video track to a different location (such as another hard drive) without deleting the video track and re-importing it?
Often times I work from home on my transport drive (G-drive mini with power supply), and thus I run my video off the same drive as well. When I go to the studio I still want to run the audio of the session from the same drive, but instead allocate the video to play from a separate drive, such as the internal SSDs.
Couldn't figure this out via the Disk Allocation window, is there another way?
Thanks!
Old 03-24-2016, 11:34 PM
EarHole EarHole is offline
Default Re: Allocating Video tracks to a different disk
Close session, copy them to a different drive, trash the ones in the current location, re-open session. It'll take a minute to re-find them but then you're al set.
Old 03-25-2016, 02:40 AM
joachim's Avatar
joachim joachim is offline
This might work :
On the G-Drive, prior to opening the session in the studio, move the video file to a different folder (on the G-Drive : maybe from "Video Files A" to a new folder named "Video Files B"),
open the session, PT will ask for a relink, relink manually to the Video Files folder of the internal SSD.
At home : relink again from Video File folder B. Back in studio, prior to opening the session there : move the video file from B to A. And so on.
PT 11.3.2 HD , RME Fireface 800 , Genelec 5.1 ,
Win7 64bit Professional , i7 3930 Hexcore , 48GB Ram , SSD System + SSD PT Session/Audio + SSD Video (all Samsung 840 Evo) + Spinner 1TB Data , 2x Radeon HD 5450 \\ SD 633 Femto MKH8060 MKH8070 MKH30/MKH40 DPA4060
Old 03-25-2016, 07:31 AM
Thanks joachim. I think this makes the most sense!
Originally Posted by joachim View Post
This might work :
Old 11-11-2020, 10:13 AM
sn_1968 sn_1968 is offline
Was hoping to do this too directly from importing an AAF/OMF. Send the video to a seperate drive for ease of data management.
Can't seem to do automatically and have to dig the video out by hand, so to speak.
Old 11-12-2020, 01:11 AM
espron espron is offline
Hi, there is an easier way of doing this.
Under the PT "Windows" menu, select New Workspace->default. Then open the folder with the PT session icon and select the subfolder "Video Files"
Then, select your video file, right-click and select "Relink". then select the location where the video file you want to use is located (G-Drive at home, SSD at work) and press find links and then commit links.
Sounds a bit convoluted, but it actually just takes about 10-15 seconds to do.
Best,
Espen
IMDB
HTML code is On
Allocating a disk for Pro Tools ilee macOS 8 01-14-2014 09:06 AM
Video Satellite LE and multiple video tracks or regions Erik Olsson Post - Surround - Video 1 01-12-2010 10:37 AM
Video track disk allocation? djkrayz Post - Surround - Video 2 10-04-2007 08:29 PM
Curious about strategies for re-allocating tracks Mark Wheaton Pro Tools TDM Systems (Mac) 3 08-20-2006 05:25 PM
Pre-allocating disk space for recording 1m1 Pro Tools TDM Systems (Mac) 4 05-04-2004 10:14 AM
