Doing a loopback test with M-Powered which is acting funny. When I send a signal out through output 7 on the 410 and then back into input 2, the recorded signal actually occurs before the audio on the originating track. I found a tiny blurb on this in the Digi white paper about Delay compensation, but searched through the DUC and the reference guide, and couldn't find anything.
Anyone know why this is happening and if it's possible to disable it? ProTools M-Powered 8.0.1 M-Audio FW410 2.16 Dual Core iMac 1.5 GB RAM OS 10.5.8 |
itīs the general problem with FireWire protocol itself and the M-Audio driver.
But itīs not limited to M-Audio alone. I had some M-Audio technician talk about it.
last: PT11.3.1 |
Does anybody else have any info on this? It doesn't seem that it could be a firewire issue. I'm not sure how firewire could make it travel back in time. I would think it would have to be a software or driver issue no?
did I say anything else than that itīs a driver Problem?
itīs a problem caused by the M-Audio driver, which cannot read the proper timing from the firewire protocol. So it has to make some 'timing estimations' which currently result in recorded Audio being placed too early in the timeline. For the tech details talk to M-Audio Support! Unless you tinkered with your Mac's Flux Compensator setting in the Time & Date System Prefs, of course. ![]()
last: PT11.3.1 |
Ah I see. It seems I misread your first post to read "It's a problem with the Firewire protocol itself..... and/or the M-Audio driver. But what was really meant was that it's an issue with how the M-Audio driver interfaces with the FW protocol.
Thanks for the clarification. Although I did install a third party Flux Capacitor in the mac, but it said it was 100% compatible so...... ![]() |
yes, they always say that, donīt trust those wacko scientists
last: PT11.3.1 |
Recording a click track causes audio files to print early? | doubtful guest | Pro Tools TDM Systems (Mac) | 2 | 03-30-2011 12:37 AM |
Recording early issue in 8.04cs2 | mattyd27 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 11-08-2010 08:10 AM |
pro tools is recording early? | Applebase | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 07-21-2010 08:44 PM |
Please help!!!! Audio is recording too early! | mrlenderful | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 05-03-2007 12:21 PM |
midi recording early?? | mrdale | MIDI | 3 | 11-21-2006 09:36 AM |
