Emac with Mbox - anyone have this setup? recomending it to my friend -is this good?
i have a g4 with a 001,
but my friend who does not have internet access ( he just came from Europe ) saw my set up and now wants me to recomend a cheap but good set up. hows this? The Emac 700mhz 40 gig HD 512 RAM running on The M box will this do the trick? does the E mac hard drive run at 7200 rpm? if not, does it do a good job still? will he need a second hard drive, or can you get by with the one HD on the Emac? is the 700mhz Emac more powerful than my 533 G4? [img]images/icons/confused.gif[/img] THANKS GUYS |
Re: Emac with Mbox - anyone have this setup? recomending it to my friend -is this good?
if he will need a second hard drive, what is the way to go? an external one right? which one would be the best? will it give the Emac any problems doing a second "external" HD? - especially since the Mbox is already slowing things down by being USB dependent.
hello?
002r/MacPro 2.8/8-core/10.6.4/PTLE 8.0.4/two internal 500gig drives/8GB ram. |
This is a quote from the Digi Mbox compatibility section:
"Mbox is supported on all Macintosh computers that shipped with a built in USB port." So yes it works on eMacs... |
Although, if my recent experience is typical, the compatibility docs may need to be revised soon. See "iBook, Jaguar Compatibility" post. Caveat emptor.
The trimmer tool in shuffle mode rocks. |
i have an emac 700 with cd writer and 256 ram.
it works perfectly with mbox. no complaints. i import projects from tdm and digi001 on it to edit the songs. that also works perfect. 24 tracks with 30+ plugins. only when bouncing the mix i get some usb warning messages. i audiosuite some plugins and connect an external firewire drive to bounce to and that worked also. i tried to record something in protools using the mbox and that was a bit tricky. i did a quick try, so i have to figure it out someday, but compared to a digi001 and tdm it was a bit annoying with latency etc. greetings, tantejo. |
My Mbox setup..is it good?? | hoganguitar | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 01-21-2006 08:08 PM |
Mbox on eMAC? | eledu | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 11-01-2004 06:55 PM |
EMAC + MBOX | ironfin | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 06-19-2004 07:35 PM |
mbox + emac | FreakyPT | Pro Tools TDM Systems (Mac) | 0 | 04-12-2004 12:56 PM |
mbox + emac | bondfast | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 10-25-2003 06:26 AM |
