Old 10-16-2007, 01:49 AM
jackie jackie is offline
Default Main control unit fader problem
All eight of the faders slam all the way to the top and stay there when you power it up. Will not go down no matter what with power on. Was in the middle of a bounce when they all of a sudden slammed all the way up and can not get it to stop. Any advice?
Thanks, Jack
Old 10-20-2007, 07:54 PM
Tweakhead Tweakhead is offline
Default Re: Main control unit fader problem
Thanks, Jack
I had the same problem. Fixed by a great Tech in LA.
Greg Granieri
[email protected]
Old 10-22-2007, 03:48 AM
Thanks, Jack
Greg Granieri
[email protected]
So what was the problem with it ? Power Supply ?
Thanks, Jack
Old 10-28-2007, 06:33 PM
Markk Markk is offline
I had the same problem and it was the power supply. My fix was expensive - but the only tech in NYC certified to work on Pro Control has a baseline charge. If it breaks again - ICON here I come.
Old 10-31-2007, 09:30 AM
agus agus is offline
I've had this problem on every unit I have...2 mains and 3 packs. Fixed it myself and it's not expensive. If you need someone to do it for you, contact me via email. www.matlin.com
TRADE: ProControl Main Unit and 2 fader packs janmuths Buy & Sell 16 05-18-2015 01:15 AM
D-Command main unit, fader pack and X-mon the glass is half empty Buy & Sell 3 06-29-2013 02:41 PM
Main Unit and fader packs FOR TRADE janmuths ProControl, Control|24, Command|8 0 06-14-2012 09:56 PM
Fader Pack thinks its a Main Unit Sleepover ProControl, Control|24, Command|8 2 05-01-2011 11:38 PM
How to make fader packs and main unit behave in unison ? warrenbonz ProControl, Control|24, Command|8 2 09-16-2007 10:22 AM
