Most stable Mac OS X for HDX / HD software
Sorry if this has been covered before...
I’m running a 2010 12 core Mac Pro I’m in the process of installing a HDX card With current HD software subscription. So licensed for all previous versions I believe. What are the most reliable Mac OS X and PT HD software versions? That play together nicely. I was thinking Yosemite and HD 12.8.1 but I’ve heard Yosemite is buggy... Thanks in advance.
https://www.glasshousestudios.com.au Mac Studio M1 Max 32 GB ram macOS Ventura 13.1 24 core Metal 3 GPU Avid MTRX Studio Pro Tools Ultimate 2023.12 HDX card AVID TB3 1 slot PCie Chassis |
Re: Most stable Mac OS X for HDX / HD software
PT12.8.1 on Yosemite is best if you also plan to run some native plugins or VIs and want to avoid the dreaded CPU spikes that cause AAE-9171 errors/Halts or AAE-9173 Halts... otherwise Sierra or High Sierra with PT2018-10 but your CPU will be spiking and you may have Playback or recording Halts from time to time.. Do not use PT2018-12 if you use many playlists... there is a SWOD/delay that happens when soloing tracks that makes it unusable for comping large playlists. AVID has confirmed this problem in PT 2018-12, -10 is fine in that regard.
High Sierra will update your MacPro firmware... I am not aware of any issues with that as long as the computer does not loose power during the process... Some current AAX Plugins & VIs and will not run on Yosemite... It is not smooth sailing... |
I'm setting up 2 x 1TB SSD - Yosemite with 12.8.1 - High Sierra with 2018.12 I do have some modern Plugin Alliance plugs (big fan here) and FabFilter too And I do use Playlists a fair bit When High Sierra updates my 2010 Mac Pro firmware will it still run ok on the Yosemite OS? I also have an old OS X Mountain Lion - will that be ok? I have HD10 and an old version of Cubase on that.... For old archived sessions I just need to get to a stable OS X and PTHD version - then I'll 'sit' until I buy the rumoured new Mac Tower.
I have worked on Mountain Lion with PT 10, with HD and HDX cards, after updating my Mac Pro firmware from a High Sierra install, and I did not notice any new issues, but it was not an exhaustive test...
I am hoping the Mojave release will solve the long existing CPU spiking and new playlist lane solo delay problem that appeared in PT2018-12. |
Same here And I like the idea of more voices in HD 2019 too Apparently I have to upgrade my video card for Mohave Something about a ‘metal’ one.
Yes, a video card that supports Metal is required for Mojave, and I think Mojave does yet another MacPro (2010 or 2012) firmware update, but don’t quote me on that. Most video cards of this nature require 2 auxiliary power cables connected, which leaves no connectors left on the Mac Pro motherboard for the extra power cable on the HDX card. There is a thread discussing this.... just be careful you don’t fry your Mac Pro motherboard circuit board power traces, others have! I am still a bit uneasy on this due to lack of concrete information on the power consumption of the cards.
Also, you likely will want a card that is Mac ready, so you can select a startup drive on power up with the Opt key... Mac flashed, and no drivers required. Last edited by Howardk; 02-14-2019 at 04:26 AM. |
Is PT 9 not stable? | SteveMc | macOS | 6 | 01-29-2011 09:30 AM |
8.0.4 cs2 - Is this stable? | JazzyJ | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 01-27-2011 12:26 AM |
The Most Stable Mac OS? | session48 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 14 | 10-30-2006 05:59 PM |
PT 7.2 / which OS is the most stable ? | Aquarius | Pro Tools TDM Systems (Mac) | 7 | 07-31-2006 09:50 AM |
Most stable OS with 6.4 | ajderrick | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 08-16-2004 09:37 AM |
