#31
Re: The Official Unofficial Windows 7 Thread
PT LE running great on Win 7 64 bit, but plugins are non functional. Can't get GR4 or Melodyne 3.0 to work!!
~2004 - Dell 4600 P4 3.0GHz, 2.0 GB Ram, XP Home SP3, 80GB HD for System, 120GB HD for Audio BIAB 2009, Pro Tools 8.0, MBox 09/12/2009 - Dell XPS 435T/9000 i7, 6G Ram, Vista 64 Bit 750 G SATA for System, 1TB SATA for Audio, Protools 8.0.1, MBox 10/31/2009 - Win 7 64Bit MBox /PT not supported under Win7 - I didn't leave PT, PT left me! 11/30/2009 - MBox, REAPER http://www.jazzmandan.com |
#32
BENONI, DUDE YOU ARE A GENIUS!! Sure enough, while I didn't put the GR4 (64 bit) into the Program (x86) directory, I did install an older version GR3 (32Bit) which did go there and the results are simply ahwsome. If you are ever in ChiTown you let me know, I own you a tall cold one.
#33
I feel so underrepresented as a sound supervisor who plays with footsteps more than drum tracks :<
Oh musicians... how I envy you Anyway, I'll post up here when I build the new i7 for W7! |
#34
For anyone out there interested as to whether the M-Audio 64 bit beta firewire drivers work or not on Win 7 x64 - they do. I've also tested the x64 beta drivers for delta cards, Audiophile 192, (PCI) and they work too.
So...from a cursory perpective, the M-Powered group can move right along. I have an 1814 and PTMP 8.0.1 running without issue at this point. I will do more testing as time permits. I'm still waiting on Digi to release x64 drivers for the 002r before I try that. Greg
Intel i7 3930K, Gigabyte GA-X79-UP4 (rev 1.0), 32 GB Corsair Vengeance 1600 ram, EVGA Nvidea GT 720 TI video card, a Samsung 850 Pro (256 GB) OS drive, 2 Samsung 850 Pro's (512 GB) in externally mounted drive bays for session and sample storage, Win 10 Pro, PT Ultimate (Native)2019.10, HD Omni, HD I/O 16x16 . |
#35
How do you change the firewire to legacy mode? I'm having the same bluescreen issue during installation of Pro Tools 8 on my Windows 7 Home Premium + 002 set up.
Thanks, DK |
#36
#37
Honestly, I've always found the Wave drivers for windows and even the Core audio for mac (esp. quicktime/itunes) to be finicky at best anyway. I run my system and entertainment audio off of my Presonus Firebox. My Mbox 2, Firebox, onboard audio, and macbook audio all run into a little mixer. Gives me more control over sourcing, as well as a quick reference if I want to hear some kind of EQ or verb on a sound effect without loading up pro tools, since I don't have the space for a PT rig and then an "other" rig. It just feels a bit more modular, and not relying on the Wave drivers is great
#38
Hello my friends,
First off, beautiful thread... focused and useful. I am running (or trying to) PT 8.0.1 on Windows Ultimate 64, 003 firewire. I am running as administrator in Vista sp 2 mode. The program is up but does not run. "Problem detected with audio clock" which is set to internal. I have read through this thread and others. If the solution is staring me in the face, I have not seen it. So.. how do I work around or tweak to fix this (oh it seems so close) I'm tired of the dual boot. Below is a Sandra and thanks in advance for knowledge and help! SiSoftware Sandra Computer Model : Dell Inspiron 530 Processor Model : Intel(R) Core(TM)2 Quad CPU Q8200 @ 2.33GHz Speed : 2.33GHz Cores per Processor : 4 Unit(s) Threads per Core : 1 Unit(s) Type : Quad-Core Integrated Data Cache : 4x 32kB, Synchronous, Write-Thru, 8-way, 64 byte line size L2 On-board Cache : 2x 2MB, ECC, Synchronous, ATC, 8-way, 64 byte line size, 2 threads sharing Computer Mainboard : Dell 0FM586 BIOS : Dell 1.0.16 12/12/2008 Bus(es) : ISA X-Bus PCI PCIe IMB USB FireWire/1394 i2c/SMBus Multi-Processor (MP) Support : No Multi-Processor Advanced PIC (APIC) : Yes Total Memory : 4GB DIMM DDR2 DDR3 Chipset Model : Dell P35/G33/G31 Processor to I/O Controller Front Side Bus Speed : 4x 333MHz (1.33GHz) Total Memory : 4GB DIMM DDR2 DDR3 Memory Bus Speed : 2x 400MHz (800MHz) Memory Module(s) Memory Module : Hynix (Hyundai) HYMP112U64CP8-S6 1GB DIMM DDR2 PC2-6400U DDR2-800 (5-6-6-18 3-24-6-3) Memory Module : Hynix (Hyundai) HYMP112U64CP8-S6 1GB DIMM DDR2 PC2-6400U DDR2-800 (5-6-6-18 3-24-6-3) Memory Module : Hynix (Hyundai) HYMP112U64CP8-S6 1GB DIMM DDR2 PC2-6400U DDR2-800 (5-6-6-18 3-24-6-3) Memory Module : Hynix (Hyundai) HYMP112U64CP8-S6 1GB DIMM DDR2 PC2-6400U DDR2-800 (5-6-6-18 3-24-6-3) Video System Video Adapter : ATI Radeon HD 3600 Series (120 SM4.1 800MHz, 1GB DDR2 2x400MHz, PCIe 2.00 x16) Video Adapter : ATI Radeon HD 3600 Series (120 SM4.1 800MHz, 1GB DDR2 2x400MHz, PCIe 2.00 x16) Graphics Processor Adapter : ATI Radeon HD 3600 Series (120SP 800MHz, 1GB 400MHz) Storage Devices Hitachi HDP725050GLA360 (500.1GB, SATA300, 3.5", 7200rpm, NCQ, 15MB Cache) : 466GB (C:) (D:) Maxtor 7Y250M0 (250GB, SATA, 3.5", 7200rpm, 8MB Cache) : 233GB (F:) Optiarc DVD+/-RW AD-7200S (SATA150, DVD+-RW, CD-RW, 974kB Cache) : 198MB (E:) Logical Storage Devices OS (C:) : 451GB (NTFS) @ Hitachi HDP725050GLA360 (500.1GB, SATA300, 3.5", 7200rpm, NCQ, 15MB Cache) Hard Disk (F:) : 233GB (NTFS) @ Maxtor 7Y250M0 (250GB, SATA, 3.5", 7200rpm, 8MB Cache) RECOVERY (D:) : 15GB (NTFS) @ Hitachi HDP725050GLA360 (500.1GB, SATA300, 3.5", 7200rpm, NCQ, 15MB Cache) untitled CD (E:) : 198MB (CDFS) @ Optiarc DVD+/-RW AD-7200S (SATA150, DVD+-RW, CD-RW, 974kB Cache) Peripherals LPC Hub Controller 1 : Dell (ICH9) LPC Interface Controller LPC Legacy Controller 1 : ITE IT8718F Audio Device : Dell (ICH9) HD Audio Controller Audio Device : Visiontek RV635 Audio device [Radeon HD 3600 Series] Disk Controller : Dell (ICH9) 4 port Serial ATA Storage Controller 1 Disk Controller : Dell (ICH9) 2 port Serial ATA Storage Controller 2 USB Controller 1 : Dell (ICH9) USB Universal Host Controller USB Controller 2 : Dell (ICH9) USB Universal Host Controller USB Controller 3 : Dell (ICH9) USB Universal Host Controller USB Controller 4 : Dell (ICH9) USB2 Enhanced Host Controller USB Controller 5 : Dell (ICH9) USB Universal Host Controller USB Controller 6 : Dell (ICH9) USB Universal Host Controller USB Controller 7 : Dell (ICH9) USB Universal Host Controller USB Controller 8 : Dell (ICH9) USB2 Enhanced Host Controller FireWire/1394 Controller 1 : Avlab Technology VT6306 VIA Fire II IEEE-1394 OHCI Link Layer Controller SMBus/i2c Controller 1 : Intel 801xx/63xx SMBus Printers and Faxes Printer : Microsoft XPS Document Writer (600x600, Colour) Fax : Microsoft Shared Fax Driver (200x200) Power Management Mains (AC) Line Status : On-Line Operating System Windows System : Microsoft Windows 7 Ultimate 6.01.7600 Platform Compliance : x64 Windows Experience Index Current System : 4.8 |
#39
I am just waiting for a driver so I can use my m-audio keystation 49e and start making some tracks with xpand and reason again.
#40
Forgot to mention (#79 above) Firewire is set to legacy. The Sandra tips mention ".NET Framework 1.1 is not installed. Install to run legacy .NET applications." This is a bit out of my league. Is it relevant?
Gracias |
THE UNOFFICIAL "DAVE C" TEST RESULT THREAD | scuzzytim | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 79 | 07-14-2010 08:21 PM |
The unofficial PTLE bottom-feeder thread! | M.Brane | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 16 | 07-18-2006 06:07 PM |
unofficial "Problems with PT7" thread | nikki-k | Pro Tools TDM Systems (Win) | 68 | 05-02-2006 01:00 PM |
---unofficial BTD report only thread--- | nikki-k | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 59 | 12-02-2003 04:29 PM |
