low quality sound when bounced to disc mbox pro tools
I just bought a Mbox 3 pro tools LE 8, and i have a Roland Fantom-S 88 keyboard where i make my beats.. and I record the entire instrumental inside the Roland, and all i want to is to digitally send it to the Pro Tools... this is my second Mbox.. on the first one i couldn't even change the sample rate from 48k to 44.1k when i was trying to send the signal from the Roland to Pro tools via SPDIF... but when i called AVID they said that it has to be something wrong with the MBOX, so i returned it back to Guitar Center.. I got the second Mbox yesterday, and now i can change the sample rate to match my Roland.. but i hear noises, like the music doesn't sound so clean... and when i bounce it to disk, and i bounce it as WAV, 44.1k, 24bit, stereo,.. and i play the beat with windows media player!! it sounds bad.. the instruments that were on the right side! i can now hear them on the left side.. and the instruments that were on left side! i can now hear them on the right side.. and the quality doesn't sounds at all like when it's playing on pro tools Real Time.. can anyone help? |
Re: low quality sound when bounced to disc mbox pro tools
It may be that WMP doesn't like 24 bit files. If it sounds good inside Pro Tools, that's a good start. Now try bounding to a 16 bit/44.1K file(insert a dither plugin on the master track, in the last slot). See how that sounds in WMP.
WELCOME TO THE FORUM RONNY
but i got to be honest with you.. it is my first time using pro tools, and i'm still not quite familiar with the software.. i have tried to bounce it at 16 bit, 44.1k.. and it still sounds bad, and the instruments switch sides.. Now, i don't know how to insert that dither plugin that you are suggesting.. can you show it to me a little bit better please? |
if you have left and right backwards then most likely so are your connections. are you using the line, mic, or instrument input on the mbox?
Did you set the clock source to SPDIF?
What do the levels look like on your Master Track? Also, can you be a bit more specific about the "low quality" issue? Is it distorted? |
Digi 003 vs Mbox 3 ? about sound quality | Tritono9 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 12-05-2011 02:12 PM |
Help with Sound Quality , Mbox Mini VS 002 - 003 | RickyRae | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 05-08-2008 06:14 PM |
Getting cd quality sound on bounced tracks? | nicball | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 15 | 02-24-2008 03:04 PM |
Sound Quality Digi 003 X Mbox 2 Pro | Pantoja | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 03-12-2007 01:38 PM |
Sound quality 003 X Mbox 2 Pro | Pantoja | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 03-11-2007 11:02 PM |
