Monitoring cuts and VST Plugins Issues
Ok guys I am stucked and need help from experienced PT users
I have 2 main issues I need help with 1* I can´t make Addictive Drummer 2 or any other VST plugin to run through PT, already tried a VST to RTAS converter called FXpansion V2.11 It wrapped the VST plugins, resulting in PT shutdown when I try to open any of these wrapped VST through the insert in my PT mix window. 2* I get all my monitoring sounds cutted, any signal coming through PT to my headphones (monitors) E.G. like a single signal generator, I get cutted sounds of that signal, or cutted monitoring from my instrument (Guitar) or from any virtual instrument I try to use from PT. If any of you can send me some lights to solve these 2 Issues, it will be very appreciated. Anyway I will keep reading and researching in the internet to try to get a solution.
Very simple set Computer Model: PC Asus Motherboard Z370P Audio Interface: Focusrite Scarlet 2i2 SO: Windows 10 pro ProTools Version: 10HD 10.3.7 |
Re: Monitoring cuts and VST Plugins Issues
Low Latency Monitoring Issues | jeffn9 | Pro Tools 12 | 3 | 12-06-2018 01:36 PM |
C24 Monitoring Issues | Dondusko | ICON & C|24 | 3 | 05-20-2018 09:50 AM |
PT10 - Audio cuts out using most plugins | wwboynton | Windows | 5 | 12-31-2011 11:35 PM |
Monitoring Issues | Cobaltsaxman | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 02-19-2007 10:57 AM |
PT 6.4 Monitoring, Metering and other issues... | Mt.Everest | Pro Tools TDM Systems (Mac) | 0 | 06-14-2004 11:46 PM |
