Go Back   Avid Pro Audio Community > Legacy Products > RTAS & TDM Plug-ins
Old 09-27-2013, 05:11 PM
capalfie's Avatar
capalfie capalfie is offline
Default VST to RTAS...pufffff!!!
Hi everyone! I am dealing here with a beast. I am trying to control my beloved JV-2080 which I refuse to sell, period! And of course it hast to be from inside Protools itself.
So far, I am stucked with Midiquest 10 XL and Protools! Midiquest has a VST version of its program to be used from inside a DAW. Problem is my wrapper, Fxpansion VST to RTAS does not want to...well..."wrapp" Midiquest VST plugin! I just cannot load it from inside PT...
Conclusion: BIG FRUSTRATION!!! grrrrr......
Any ideas that would help calm me down?
Thks!
Nobody said it was easy...
MacBook Pro 15" | I7 | 16GB | 500G SSD | 4T Ext G Thunderbolt 2 Drive | Apple Cinema Display 27" | OS 10.12.6 Sierra | Focusrite Clarett 8Pre | Motu Midi Express | Pro Tools 12.8 Native | Roland JV-2080 | Digitech 2101 - Guitar Studio Tube Artist Upgrade| And some other toys...
Old 09-27-2013, 06:31 PM
Default Re: VST to RTAS...pufffff!!!
Thks!
Either get a trial of MB-7 2 and try to host in there or host it in reaper and Rewire it in PT.
pro-tools-pc.com
TRASHER Pro Tools Utility(updated 4-11-2024)
Intel I7 9900k
Win 10
Old 09-28-2013, 12:46 AM
crizdee's Avatar
crizdee crizdee is offline
Thks!
Have you gone into the wrapper and manually selected to wrap this plugin.
I findi have to scan everything then go through the list and turn on the ones I want.
Is the VST version installed ok and WORKING as a VST? It must be working as VST for the wrapper to be able to convert it.
Chris
Producer, Engineer,
www.ukmastering.com
Old 09-28-2013, 01:17 AM
kwz kwz is offline
Thks!
Win or Mac?
Old 09-28-2013, 11:04 AM
capalfie's Avatar
Thank you Guitardom, I will try them both and post here the results!
Old 09-28-2013, 11:12 AM
capalfie's Avatar
Originally Posted by kwz View Post
Win or Mac?
Thanks kwz, sorry I forgot to post my set up... I will add it to my signature...
I am under Win 7 Ultimate 64, I7, 8GB ram, Fast Track Ultra 8R, Protools 9.06...
Old 09-28-2013, 11:16 AM
capalfie's Avatar
Originally Posted by crizdee View Post
Chris
Hi crizdee, thanks for you help. Yes, I have tried that manually. I have no idea if the VST version is ok. I am using Midiquest and it is supposed to be a serious program. This program add a dll for the JV-2080 to my vstplugin directory. Then I am supposee to wrapp it with Fxpansion...but this is failing...
Old 09-28-2013, 12:37 PM
kwz kwz is offline
maybe the dll that got scanned by the adapter is the x64 version, so it failed at detection?
and, have you tried to disable UAC?
Old 09-28-2013, 06:33 PM
capalfie's Avatar
UAC is disabled. But I am lost about the 64...mmmm....I have both versions of Midiquest, 32 and 64...which one am I suppose to install considering I am using PT9, 32 bits and Fxpansion wrapper, 32 and everything inside a 64bit Win 7 version? Hmmm.... I have installed both, 32 and 64 and had problems wrapping with both, but perhaps the error is in how to install it...perhaps should I uninstall everything, clean up registry and start all over just with the 32bit version???? Lost and confused here...
Old 09-28-2013, 09:01 PM
With PT 9 you would use the 32 bit VST. The Rtas wrapper is not going to wrap 64 bit VST since Rtas, wrapper, and PT are all only 32 bit.
pro-tools-pc.com
Intel I7 9900k
Win 10
Is there a way to convert vst to rtas without vst to rtas adapter? rockguitarist1255 Pro Tools 10 9 01-11-2012 08:35 AM
UAD go RTAS SSL RTAS in V4 coming soon crizdee Pro Tools TDM Systems (Mac) 60 09-11-2011 10:10 PM
Why can't I monitor RTAS on Insert A? Line6 Gearbox RTAS Justin1524 Pro Tools TDM Systems (Mac) 3 05-12-2007 07:44 PM
McDSP / HD RTAS vs Native RTAS tclash 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 10-01-2006 08:01 PM
Ozone with wrapper?? or rtas- T-racks RTAS ???? Camilo Toledo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 04-14-2004 06:35 AM
