Old 11-02-2009, 05:01 AM
johnbhoy johnbhoy is offline
Default Midi keyboard broken Help with repair
Does anyone have any know how on how to fix a midi keyboard or give an indication what might be wrong with it.
I have a oxygen8 copy by carillion. Basically the same keyboard just a different badge on it.
Very recently the led display has started jumping about like there is a short somewhere. This affect all the controllor knobs so this is really inconvienent when trying to control a plugin and the parameters keep jumping about. Its like something is flickering and affecting the values of the pots. The puts now also don’t send a full 127 value. They all go from 0-122 or sometimes 0-123 or 0-120. have tried resetting the keyboard.
Have tried different usb ports and also tried using the keyboard with the cs10 profile instead of the m-audio profile I am currently using incase a setting was causing this but I definitely think it’s a hardware fault.Have also tried changing usb cable incase that was faulty.
I will be taking it apart to have a look at it. But was hoping anyone could chip it with anything I should be looking for that might be up with it.
Midi Clips View Problem, option + "-" keyboard shortcut broken kingtinker Pro Tools 10 5 09-25-2016 01:47 PM
Keyboard access of menu commands broken in 11 b1daly Pro Tools 11 17 04-11-2016 06:20 AM
RTAS Capslock Keyboard? Midi Keys triggered from computer keyboard. aasteveo Pro Tools 9 0 11-06-2011 06:17 AM
Great Deal on a Broken Ramsa DA7 and $4.85 to repair it! guitar012001 Pro Tools TDM Systems (Mac) 0 05-29-2011 06:16 PM
Broken audio file, how to repair? maxserg Pro Tools TDM Systems (Mac) 4 05-30-2006 03:38 PM
