Pro Tools M-Powered at 96khz: is it working properly?
In this post on KVR, testing EQs under different hosts (with an emphasis on Pro Tools LE/M-Powered) is discussed a lot with the implication that the Pro Tools RTAS versions of plug-ins such as Sonalksis SV-517 MK II don't work consistently at 96khz as compared to 48khz under Pro Tools LE/M-Powered as compared to consistent performance between the Audio Units and VST versions of the same plug-ins under different sample rates in multiple hosts on both Windows and Mac OS X.
Here is the link to the post KVR:EQ-ing at 96khz vs. 48khz In the post a link is also given to audio files of the output of Sonar (as an example of a non-Pro Tools host EQ behavior) and Pro Tools, both at 48khz and 96khz with the exact same EQ settings in same plug-in. Audio Examples Can anybody explain why the Pro Tools example at 96khz sounds so different from all the others? It sounds almost like it is targeting a different EQ band. |
Digidesign Midi IO not working properly in Pro Tools 11.1 HD on Maverick! | bigknowsal | Pro Tools 11 | 1 | 01-05-2014 07:39 AM |
Can't get my pro tools le 8.05 working properly | rockposer | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 06-05-2011 12:27 PM |
Signal from Profire 2626 to pro tools isn't working properly | beasleymusic | Pro Tools M-Powered (Win) | 2 | 08-21-2010 08:09 PM |
96khz Issue (also affects M-Powered) | creator | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 12-01-2007 11:49 AM |
projectmix + m-powered at 96kHz? | delpinator | Pro Tools M-Powered (Win) | 6 | 10-26-2006 01:19 PM |
