No Pan Control when opening old Session? I/O?
Hey all, thanks in advance.
I open a PT7 session in PT2021 - reset my I/O to current - select 'mono default format' but there's no pan control on all my audio tracks and what appears to have everything coming out of both left /right. There are 9 session files from PT7 and 3 out of the 9 open this way - the other 6 are fine. What silly thing am i missing? Thanks again
www.boneheadstudio.com Dell I9 32GB Ram Win 10 PT2020 Allen & Heath Qu32, AB168, 5 x ME500 |
Re: No Pan Control when opening old Session? I/O?
I've seen missing PAN knobs when a track doesn't have an output. If you see outputs, I would assign all tracks to no output, then change to your desired stereo output path.
thank you, Albee as always over so many years...a true rocker!
bigger questions is why is the I/O such a hassle ??? and why does my I/O not match what my patching options on the output channels?...etc. seems this output is locked to a random mono channel (25) out putting to my default stereo out 31/32 - hence - no pan. I tried your medicine and set to 'no output' and then re-instate, but no any thoughts, i certainly appreciate! Thanks again
Hmmm, Did this session come from another system? Does this happen with all sessions?
Assuming the correct device is selected as the "audio engine", open Setup>IO and start on the Bus tab. Look for duplicate names/paths(delete any duplicates). Scroll all the way down(looking at entries that have a green check) and make sure everything looks correct. Then hit the Output tab and look for similar. I'm still confused by this: reset my I/O to current - select 'mono default format' If you are outputting to mono, then there can't be any pan knobs. Make sure you are using a stereo output. Hopefully, something here will help(of course, trashing prefs is an option too)
Once again Albee, thank you. I always forget to clear the Bus and there was a wacky 'Mono-25 Output -> Main Stereo Out!
And yes, i get confused on the Mono/Stereo format and had that reversed as well. I all good now and you are always on in! Thanks mate
what is up with the session I/O dialog upon opening a session | Rectifried | Pro Tools 11 | 22 | 06-09-2015 08:07 AM |
PT 11.02 freezing after closing a session and opening new session | asaffulks | Pro Tools HDX & HD Native Systems (Win) | 2 | 12-17-2013 01:49 PM |
opening leopard session in Snow Leopard, quit on opening! | crizdee | Pro Tools TDM Systems (Mac) | 0 | 06-12-2010 02:03 AM |
Opening session from LE 5.1.1 into 6.0 | yomomsastinkygoat | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 11-26-2005 05:31 PM |
Problems with Opening TDM Session in LE Session | BenTerry | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 01-19-2004 12:53 PM |
