Go Back   Avid Pro Audio Community > Live Sound > VENUE Live Sound Systems
  #31
Old 12-03-2014, 11:43 AM
jacko's Avatar
jacko jacko is offline
Default Re: S3L Venue Link trouble
Originally Posted by milaszewski View Post
I used to run Venue Link with S3L 4.1 with no problems. Now I borrowed another console updated to 4.5 and here is what happens:
- Pro Tools can see the console in Venue link tab in Peripherals after I set up ports correctly
- when I choose it, it shows (inactive)
- S3L Interaction tab shows "not connected"
AVB over the same cable works fine.
I did all troubleshooting steps from the manual multiple times and I could never get it connected.
UPDATE, THE SOLUTION:
The procedure described by Sheldon above solves the problem.
Originally Posted by Valentyn View Post
So, to summarize:
Venue Link port setting needs to be kept at 29292 (default value) in VENUE 4.5.0/4.5.1 in order to establish a connection to Pro Tools.
UAD Apollo x16,
UAD Apollo Twin Duo,
UAD Octo Thunderbolt,
Mac Mini i7 2018,
Reaper DAW,
Presonus Faderport,
Arturia Beastep for DAW control,
Former Pro Tools HD user (from V7 until V12.6).
  #32
Old 12-05-2014, 03:38 PM
LanceK LanceK is offline
I must say that Venue Link is NOT easy to get hooked up and working. There should be a way with Pro Tools and Venue to make this built in. If you connect an ethernet cable to the 2 of them, it just works. It took us hours to get it to work the first time. Just saying....
System Details: Macbook Pro 17"
OS 10.7.5
PT 10.0
8 gig ram
FW Drives (Multiple)
eSATA Drives (Multiple)
[email protected]
Having trouble getting SC48 to work with Venue link on alternate network interface blantonlew VENUE Live Sound Systems 2 07-12-2013 11:36 AM
Venue link (inactive) kurt-jen VENUE Live Sound Systems 1 09-29-2011 08:15 PM
Venue link issue digidesigner VENUE Live Sound Systems 13 07-19-2011 06:44 AM
Venue Link and VNC mariojorgeandrade VENUE Live Sound Systems 2 11-16-2010 08:27 AM
Cannot link Venue SC48 to laptop with FWx jmillgrip VENUE Live Sound Systems 7 03-24-2010 01:05 AM
