Pro Tools M Powered - Upgrading Question
I'm about to purchase an M Audio USB interface, that comes with a copy of Pro Tools M Powered.
My question is, how similar is this to the other versions of Pro Tools? Is there much difference? Are they similar in nature and layout? I don't want to start over again when I decide to upgrade. I'd rather stick with just one application like Pro Tools, than bounce all over the place, trying to learn Logic or something else. And I can assume Reason can be wired into Pro Tools M Powered, no problem? Thanks. |
Re: Pro Tools M Powered - Upgrading Question
Pro tools is pro tools regardless of the version. Once you learn on a version, they are basically the same. Key commands and layout is basically the same. Their are some advanced feature not found in Le and m-powered. Below is a comparison list of features found in all versions of pro tools.
http://www.avid.com/us/products/fami...-Tools/compare Later, Scott |
Thanks, Scott. That's exactly what I needed to know.
Upgrading to Pro Tools 10 from M-Powered | TRUN | macOS | 2 | 12-22-2012 08:21 PM |
Upgrading from M-Powered to regular old Pro Tools... Will this cause problems? | shotgunjoe | General Discussion | 0 | 03-11-2012 10:54 AM |
Help Upgrading from Pro Tools M-Powered | thglif52 | macOS | 0 | 12-09-2011 04:06 PM |
Upgrading to Pro Tools 9 from M-Powered..? | TRUN | macOS | 1 | 05-04-2011 07:07 PM |
upgrading to pro tools 8 with m powered and LE?? | taekwon | Pro Tools M-Powered (Mac) | 2 | 10-15-2009 06:42 AM |
