Is My System Good Enough For PT LE 8?
i have a AMD system this is why i ask lol
this pc was hand built by me my biggest concern is the chipset....is it correctand will it work good for PT LE? .SiSoftware Sandra Computer Model : System manufacturer System Product Name Workgroup : group Host Name : davespc User : Studio Processor Model : AMD Phenom(tm) II X4 965 Processor Speed : 3.41GHz Cores per Processor : 4 Unit(s) Threads per Core : 1 Unit(s) Type : Quad-Core Integrated Data Cache : 4x 64kB, Synchronous, Write-Back, 2-way, Exclusive, 64 byte line size L2 On-board Cache : 4x 512kB, ECC, Synchronous, Write-Back, 16-way, Exclusive, 64 byte line size L3 On-board Cache : 6MB, ECC, Synchronous, Write-Back, 48-way, 64 byte line size, 4 threads sharing Computer Mainboard : Asus M4A78T-E BIOS : AMI 2402 01/05/2010 Bus(es) : ISA X-Bus PCI PCIe IMB USB FireWire/1394 i2c/SMBus Multi-Processor (MP) Support : No Multi-Processor Advanced PIC (APIC) : Yes Total Memory : 3GB DIMM DDR3 Chipset Model : AMD RS780 Host Bridge Front Side Bus Speed : 2x 2GHz (4GHz) Memory Bus Speed : 2x 101MHz (202MHz) Chipset Model : AMD F10h Athlon 64/Opteron/Sempron HT Hub Front Side Bus Speed : 2x 2GHz (4GHz) Total Memory : 6GB DIMM DDR3 Memory Bus Speed : 2x 536MHz (1GHz) Memory Module(s) Memory Module : OCZ OCZ3G1600LV2G 2GB DIMM DDR3 PC3-8500U DDR3-1066 (7-7-7-16 4-26-8-4) Memory Module : OCZ OCZ3G1600LV2G 2GB DIMM DDR3 PC3-8500U DDR3-1066 (7-7-7-16 4-26-8-4) Memory Module : OCZ OCZ3G1600LV2G 2GB DIMM DDR3 PC3-8500U DDR3-1066 (7-7-7-16 4-26-8-4) Video System Video Adapter : ATI Radeon HD 4870 X2 (2x 800 SP 750MHz, 2x 1GB DDR5 4x900MHz, PCIe 2.00 x16) Graphics Processor Adapter : ATI Radeon HD 4870 X2 (2x800SP 10C 507MHz, 2x1GB 500MHz) Adapter : ATI Radeon HD 4870 X2 (2x800SP 10C 507MHz, 2x1GB 500MHz) Storage Devices WDC WD5000AAKS-65A7B0 (500.1GB, SATA300, 3.5", 7200rpm, NCQ, 16MB Cache) : 466GB<---------Recording Drive SAMSUNG HD300LJ (300GB, SATA300, 3.5", 7200rpm, NCQ, 8MB Cache) : 279GB (F:)<--------Gaming Drive SAMSUNG HD300LJ (300GB, SATA300, 3.5", 7200rpm, NCQ, 8MB Cache) : 279GB (G:)<-------- Storage Drive WDC WD10EACS-65D6B0 (1TB, SATA300, 3.5", 7200rpm, NCQ, 32MB Cache) : 932GB (C:)<---------Pro Tools Install WDC WD10EACS-65D6B0 (1TB, SATA300, 3.5", 5200rpm, NCQ, 16MB Cache) : 932GB (H:)<--------storage drive only ATAPI DVD A DH22A9P (ATA66, DVD+-RW, CD-RW, 2MB Cache) : N/A (D:) ATAPI DVD A DH22A9P (ATA66, DVD+-RW, CD-RW, 2MB Cache) : N/A (E:) Logical Storage Devices backup2 (F:) : 279GB (NTFS) @ SAMSUNG HD300LJ (300GB, SATA300, 3.5", 7200rpm, NCQ, 8MB Cache) recording drive (G:) : 1TB (NTFS) @ SAMSUNG HD300LJ (1TB, SATA300, 3.5", 7200rpm, NCQ, 32MB Cache) Studio XP (C:) : 149GB (NTFS) @ ST3160318AS (160GB, SATA300, 3.5", 7200rpm, NCQ, 8MB Cache) Game Box (H:) : 932GB (NTFS) @ WDC WD10EACS-65D6B0 (1TB, SATA300, 3.5", 5400rpm, NCQ, 16MB Cache) Optical Drive (D:) : N/A @ ATAPI DVD A DH22A9P (ATA66, DVD+-RW, CD-RW, 2MB Cache) Optical Drive (E:) : N/A @ ATAPI DVD A DH22A9P (ATA66, DVD+-RW, CD-RW, 2MB Cache) 3.5" 1.44MB (A:) : N/A Peripherals LPC Hub Controller 1 : ATI (AMD) IXP SB600 SMBUS Controller LPC Hub Controller 2 : ATI (AMD) SB700 LPC host controller LPC Legacy Controller 1 : ITE IT8720F Audio Device : ASUS IXP SB600 High Definition Audio Controller<------ disabled by me Audio Codec : VIA 0397h<------------------------------------------ disabled by me Audio Device : ATI (AMD) HD48x0 audio<-----------------------------disabled by me Audio Codec : ATI (AMD) AA01h<------------------------------------disabled by me Avid Mbox3 Mini <-----------------------------------------------------------------------CURRENT RECORDING INTERFACE Serial Port(s) : 1 Disk Controller : ATI (AMD) SB700 SATA Controller [IDE mode] Disk Controller : ATI (AMD) SB700 IDE USB Controller 1 : ATI (AMD) SB700 USB OHCI0 Controller USB Controller 2 : ATI (AMD) SB700 USB OHCI1 Controller USB Controller 3 : ATI (AMD) SB700 USB EHCI Controller USB Controller 4 : ATI (AMD) SB700 USB OHCI0 Controller USB Controller 5 : ATI (AMD) SB700 USB OHCI1 Controller USB Controller 6 : ATI (AMD) SB700 USB EHCI Controller USB Controller 7 : ATI (AMD) SB700 USB OHCI2 Controller FireWire/1394 Controller 1 : ASUS 3403h FireWire/1394 Controller 2 : Creative Labs Audigy 2 Firewire Controller SMBus/i2c Controller 1 : ATI SB600 SMBus SMBus/i2c Controller 2 : ATI AFS SMBus Printers and Faxes Printer : Microsoft XPS Document Writer (600x600, Colour) Network Services Network Adapter : Atheros AR8121/AR8113/AR8114 PCI-E Ethernet Controller - Packet Scheduler Miniport (Ethernet, 100Mbps)<------- disabled when recording Power Management Mains (AC) Line Status : On-Line Operating System Windows System : Microsoft Windows XP Professional 5.01.2600 (Service Pack 3) Platform Compliance : x86 |
Re: Is My System Good Enough For PT LE 8?
Yes and no
those 8 MB hard drives will not play nice with protools, same with the 5400 RPM drives. get something at least 7200 RPM and 16MB cache. Make sure protools is on a separate drive form your sessions. Everything else looks good to me. what type of interface are you thinking of using? If its USB, make sure you disable power management on USB ports via device manager. If its a firewire interface, make sure its a TI chipset. Nick
Core i7 920 OC'ed @ 4.0 GHz (200 X 20) 12 GB Patriot Viper Extreme Asus P6T OCZ Agility 64 GB SSD Hitachi 1TB 32 MB HDD WD Caviar Black 500GB Saphhire HD 5850 3 x 20" monitors Eleven Rack w/ ERXP Fender Super Champ XD Marshall JCM2000 DSL100 Silver Edition W/ Silver Jubilee Cabinet |
I'm new to PTools and digital recordiing. last Spring I built an AMD Tri-core Phenom on an ASUS motherboard similar to yours, and bought a new internal 500 gig WD similar to yours. I could not get PT LE to run (started with XP system). I had to disable ALL USB devices, including an external 300 gig WD and also a USB hub with nothing connected as well as my USB keyboard and mouse. I finally got it to load and run bits of session, the problem apparently being within my Mbox 2 I guess. But when McAfee updates crashed XP systems last summer, I updated to WIN7, and all kinds of problems again. I have finally reverted to a 6 year old Gateway Media Center running a new copy of XP on a completely reformatted hard drive, with a 2nd internal 500 gig Seagate as my PT drive. I have no internet, no virus scan, and NO USB peripherals (using wired mouse and keyboard) and a single core (old Pentium) processor with 2 gigs ram. So far it's doing what I ask it to do.. though I'm much too new to place any real demands on it yet. Good luck on your AMB build. Please post your results as you go through setup.
Pro Tools the program should be installed on your System Drive, ie C:
Cheers,
Good System Usage/RTAS settings for Quad Core system | Mental Clarity | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 12-19-2008 03:09 PM |
good cue system? | Reverend Dan | Tips & Tricks | 3 | 10-21-2002 11:33 PM |
Is my DAW system good enough? | Beto | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 01-21-2002 09:48 PM |
Is This System Good Enough? | yorta | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 10-05-2000 05:40 AM |
Is My System Good Enough? | parisblack | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 07-20-2000 08:11 AM |
