  #281
Old 10-13-2012, 10:45 AM
gullfo gullfo is offline
Default Re: NEW UPDATED Room Calibration for Film and TV Post
here's a quick diagram on the Genelec site: http://www.genelec.com/documents/qsg...es_diagram.pdf
Glenn
www.runnel.com
  #282
Old 10-15-2012, 07:32 AM
EvilTuna7 EvilTuna7 is offline
Originally Posted by dr sound View Post
ALL THE LINKS ARE FIXED as of 10-10-12
Thank you very much!
  #283
Old 01-26-2013, 04:48 AM
Olukunle Olukunle is offline
Thanks a lot!
iMac 21.5" Quad Core, 4GB RAM
Mac OS X Lion
MBOX 2 Pro Factory, Pro Tools 10
M-Audio BX8 (UK Version)
2.0TB OWC Mercury Elite-AL Pro FW400, 7200rpm, 64mb
  #284
Old 03-16-2013, 12:10 PM
dr sound's Avatar
dr sound dr sound is offline
There is New 3-16-13 "ROOM CALIBRATION CHEAT SHEET LINK" from Danijel Milosevic in the 1st post on the "Room Calibration Thread"
Marti D. Humphrey CAS
aka dr.sound
www.thedubstage.com
IMDB http://www.imdb.com/name/nm0401937/
Like everything in life, there are no guarantees just opportunities.
  #285
Old 04-08-2013, 05:44 AM
Roger Stauss Roger Stauss is offline
Default A big Thank You
Just wanted to drop a line to all the contributors to this post. Very helpful information. All too often I drop into the Users Forum, extract good information and forget to thank you all!
So...Thank you!
  #286
Old 05-12-2013, 10:54 AM
dr sound's Avatar
There is a New ATSC A-85 2013 Updated Link on the First Post.
Please click and read for the latest updated info.
aka dr.sound
www.thedubstage.com
  #287
Old 12-16-2013, 08:49 PM
Marcel Risberg's Avatar
Marcel Risberg Marcel Risberg is offline
I am somewhat new to calibrate for bass management in a studio environment. Up until now I've only been reading about it and understood it somewhat in theory. I've also been using full range speakers LCR and ignored any low bass missing from unmanaged surrounds up until now. Now I'm rebuilding my home studio and trying a few different speaker systems and setups to see which one suits my new needs.
I was just trying out the calibration files and instructions found at abluesky.com and I'm running across a few issues. (Ps. It has been in the middle of the night at my place so I've used a lower volume setting, -20dB and -30dB from ordinary calibration level.)
The dBC-meter I was using measured 64.8dBC at a volume control setting of -20dB and 55dBC at -30dB using the HF file (500-2500Hz) and beginning with the front left speaker alone. Then all channels (still SATs only, no sub) were calibrated alike.
Then I got to calibrate my bass management. This was when I hit a few bumps. So, when playing the LF file (40-80Hz) through the left speaker alone - sub still turned off - I got a reading of 62.4dBC (@-20dB) and 52.8 (@-30dB). When playing the same LF file through the sub, with the SATs turned off, I got a reading of 63.7dBC (@-20dB) and 53.8dBC (@-30dB). Again the same LF file but with both Sat and Sub turned on I got 67.2dBC (@-20dB) and 57.3dBC (@-30dB).
I believe it could be even clearer over at abluesky about what of the above example to calibrate to - Sat alone or together with sub. Anyone care to chime in?
I understand there are more parameters to set to calibrate bass management. I was thinking of keeping my question short and take it from here to begin with.
Thanks!
Marcel Risberg
Production sound and audio post - ljuddesign.se
Enthusiastically sharing knowledge and experience at Stockholm Film School.
🛠 Pro Tools Ultimate 2019.10 · HD Native · HD Omni
🎚 EuControl x.x.x · Artist Control · Mix · Control App
🦑 MacPro5,1 · 12C24T @3.46GHz · 48GB · SSDs · macOS 10.13.6 (17G5019)
📺 Separate video playback machine
🥇 Covered by ZDT/TLC · Keeping DAW OS clutter free
  #288
Old 02-01-2014, 05:26 AM
yazoo yazoo is offline
Default mixing @ 82
Hi!
We have a smaller mixstage,
cal @ 85.
I want to mix my next film @ 82
should i re-calibrate @ 82, or just turn down my monitoring?
is this the right way to cal @ 82?
pinknoise full @ -20 dBFS:
82 LCR 79 Ls Rs ?
Benny
  #289
Old 09-02-2014, 12:49 PM
dr sound's Avatar
Default Re: mixing @ 82
Originally Posted by yazoo View Post
Hi!
cal @ 85.
82 LCR 79 Ls Rs ?
Benny
Benny,
Turn down your room monitor which you calibrated to 85 and then adjust your monitor to 82. The levels should SHOULD BE:
82 LCR 79 Ls Rs ?
aka dr.sound
www.thedubstage.com
  #290
Old 04-05-2015, 01:23 PM
dr sound's Avatar
New addition to my "New Updated Room Calibration",
The very first post, see:
NEW AS OF APRIL 5, 2015
Another very interesting article from Meyer Sound on "Calibrating Cinema Sound Systems"
aka dr.sound
www.thedubstage.com
HTML code is On
Room Calibration - ATSC Standards - Help mikevarela Post - Surround - Video 20 08-29-2013 09:26 AM
D-Control output calibration for film... Pete@twenty7pix ICON & C|24 2 02-28-2011 10:10 PM
Meters for room calibration idris Post - Surround - Video 3 09-23-2010 05:27 PM
Calibration in a small room... joeyk Post - Surround - Video 3 05-08-2006 10:02 PM
Room Calibration and Levels for LE Starcrash Post - Surround - Video 8 08-03-2005 10:40 AM
