#21
Re: Dolby Atmos hardware requirement for Production/Mastering suite
For an external RMU you will need physical interface connections, either MADI or Dante, the ethernet connection for metadata and the LTC source from PT.
Regards, Paulo M MAC Studio MAX M1_64 GB RAM_1TB SSD_MAC OS Ventura Protools Studio 2024.3 |
#22
Which by the way, DAD does not sell anymore (digilink expansion card) as part of the agreement on manufacturing the MTRX for AVID.
#23
I think he might just referring to needing two HDX cards for Pro Tools. Not two digilink expansion ports on the MTRX. I could be wrong.
Pro Tools Ultimate, HDX3 & MTRX + HD MADI 7,1 MacPro, 3.2GHz 16-core, OSX 10.15 S6 M40 48-5, panners, MPM,Dolby Atmos RMU AJA Kona LHi, Sync HD www.ToolshedAudioPost.com www.TheToolshedStudio.com Certified for Dolby Atmos Home Entertainment |
#24
This makes the step of premixing Atmos in a small room, going to a RMU equipped stage a lot faster / easier! |
#25
Can someone elaborate what are the steps that needs to be done when going from HDX (send/return) set up to the RMU equipped Atmos stage? Can that be prepared before sending session over? How much time approximately is needed?
#26
When using the DAB, the first step is to set the playback engine in Pro Tools to Dolby Audio Bridge. That gives you 130 output channels (in PT 2019.10+ only). The 128 are what feed the Local Renderer software(on the same computer) In the Audio setup part of the Local Renderer, you would set the Input to Dolby Audio Bridge and the Output to HDX.
You will not be able to use the send/return plug ins in this setup. You will set the output routing in the I/O page of the pro tools session to match the inputs (Beds/Objects) for the Local Renderer. This setup is really meant for things like pre-mixes and the like. Dolby will tell you that this is not a great way to create masters. For some of the other questions, Pro Tools can only output 32 channels of audio per Digilink port - so 64 channels per card. The MTRX can output a ton of audio, but only functions out of the box as a 64 channel PT interface. This can be augmented with additional Digilink ports. Randall
Randall Smith Audio Editor/Mixer Starz Entertainment Group Denver, CO |
#27
So bottom line, if one uses a dedicated HT RMU, the PT Ultimate rig must use 2 x HDX cards because this is the only way to have 128 outputs, correct ?
I have a nMP with PT Ultimate (thunderbolt Native), AX32 with Digilink (same interface as MTRX, i bought it before Avid team up with DAD). I also have a spare nMP with Rednet PCIe Dante that i was thinking of using as a dedicated HT RMU. If i understand correctly, i will need 2 x HDX card and an additional Digilink card for my AX32 for it to work, correct ? |
#28
You require HDX2 for 128 channels of outputs from Pro Tools... but unless you are reaching for Dolby Atmos certification, I don't think you need to actually use 128 channels. 64 channels would still give you a bunch of beds and a lot of objects to mess around with!
Pro Tools Ultimate 2024.3. OSX 13.6.5. Win 10. HD Native. Lynx AES16e. Lynx Aurora 16. i9-13900KF. ASRock Z690 Steel Legend. 64GB Ram. AMD Vega 64. BM Decklink. Dolby Atmos Renderer 5.2. Trinnov D-Mon. D-Command. |
#29
I tend to agree with LDS. For those of us HD Native users mixing docs, dramas, un-scirpted, etc.-- 36 bed channels (3x 7.1.4) and 16 object channels and 12 for monitoring seems more than adequate... am I missing something? Otherwise we're talking HDX2, additional dig-link, et. al.--a much larger barrier to entry.
#30
Can't get that for the AX32. Only the MTRX supports the new digilink cards.
Dolby Atmos Production Suite 3.02 download | LDS | Post - Surround - Video | 3 | 08-20-2019 07:03 AM |
Dolby Atmos Production Suite renderer on another computer | nedd | Post - Surround - Video | 7 | 04-24-2019 08:11 AM |
Dolby Atmos Production Suite Installer V 2.5 | tatoflores | Post - Surround - Video | 1 | 04-21-2019 09:46 AM |
Dolby Atmos Production Suite | garnoil | Post - Surround - Video | 2 | 03-13-2019 08:34 AM |
Dolby Atmos Production Suite | subhuffer | Post - Surround - Video | 20 | 03-10-2019 06:40 AM |
