Help! PT Recognizes Audio Interface with 1 card but not with 2 cards!?
Experienced user here but stumped with this one.
Lynx Aurora 16 with LTHD, PT Core card + 4 Accel cards. System worked perfectly but computer motherboard blew. Replaced motherboard. Everything works with just HD Core...but... Added 1rst Accel card and "Can Not Recognize Interface" dialog box appears at launch. Accel card passed digitest. Tried another Accel card with different flex cable, same problem. This is a new system drive with freshly installed PT software and plugs. For testing, all plugs removed from plugs folder, all prefs trashed. I'm at my wits end on this. Wondering if it could be the second PCI slot is defective, but the card passes the Digitest in that slot. Can anyone suggest something I may not have thought of? As I said the system was previously working fine with this same configuration. Thanks! System: PT10.39 HD TDM with 4 Accel cards OS 10.68 Previously working perfectly in this configuration |
Re: Help! PT Recognizes Audio Interface with 1 card but not with 2 cards!?
Problem Solved! For the benefit of future generations...
The tech who replaced the motherboard installed the flex cables (going between the TDM cards) in reverse. Not being a Pro Tools user his decision was logical -connected socket A of first card to B of next card and so on. Reviewing the Installation Guide it actually works in the illogical manner of B to A. Prior to noticing this, as a last desperate attempt, I tried connecting the Audio Interface to the last card in the chain (not the first card, the Core Card, as is proper) and Pro Tools recognized the interface! Realizing something must be backwards I went back to the manual and discovered the error. |
True. And nothing breaks if you do it backwards, only that PT is routing to different interface numbers than you would expect I did that too back in the day... wanted to give a good slap in the face to the person who decided to label them wrong.
PT 11 recognizes Fast track solo but doesn't as an interface input! | RiffVomit | FireWire & USB Audio Interfaces (Mac) | 2 | 12-27-2014 08:05 PM |
Anyone using a PCI-E firewire card to connect their audio interface? | RuffinMedia | macOS | 2 | 02-28-2012 01:34 PM |
unable an audio interface attached to the first hd card | delphypop | Pro Tools TDM Systems (Mac) | 0 | 06-17-2010 04:21 AM |
Computer recognizes wrong interface | taperocket | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 11-11-2005 10:26 AM |
882 1/0 audio interface with mix core card | pmurf | Pro Tools TDM Systems (Win) | 1 | 02-24-2004 11:00 AM |
