Problem with mixed s/r OMF from adrenaline systems
Hi all, i have a question, i dont know if it has been up for discussion in this forum before but ill ask anyway.
When i try to import OMFs from some adrenaline systems i get the error messages; PT doesnt support mixed s/r in 5.3.1 or problem determining s/r in 6.2x. When opening the OMF in any Avid and checking s/r in the bin and media tool it appears that all audio is of same s/r 48kHz. I have tried to decompose and relink, convert, reconsolidate, consolidate and export both embedded and linked again in our 9000, symphony and adrenaline systems, but i get the same error every fxxxxxxg time i try to open the OMF in PT. Ideas anyone? All help really appreciated. This is a daily 48 min tv-show so mixtime is money and beer... |
Re: Problem with mixed s/r OMF from adrenaline systems
I've only had that problem when the Logic session which created the OMF files had mixed sample rate sound files embedded.
Try downloading the new 6.4 version with OMF fixes. Rail
we've had exactly the same problem.
we discovered the cause is probably down to at least one of the sounds in your omf having been converted to the project sample rate by using the avids internal conversion utility. Digidesign did recommend deleting the video tracks prior creating the OMF, but as our files were audio only without any video (pre-filming animation dialogue tracks!) this was obviously not the answer, although it might be for you. Also you may be able to open the omf with either omftool or digitranslator 1 - as both these were more tolerant of error than the digitranslator 2 that is part of 6.xx. then save as a pt session that way. good luck.
adam taylor video editor/dubbing editor/sound design/motion graphics/compositor United Kingdom |
As Rail mentioned, there is a new cs release today that addresses OMF issues with the newer AVID systems. 6.4cs7. See if that helps you out.
Mark Ettel C.A.S. |
My AVXL is not supported by 6.4.
I saw the same problem last month twice coming from an audio-only Nuendo omf export. I had to use Digitranslator 1.0. It is a shame that shortly afterwards the OS9 boot drive self destructed and took my remaining floppy authoriaztion with it. Now what do I do?
Call me by my real name, "Postman" |
Thanks to you all ofr your replies and ideas, 6.4 cs7 would be great but as Richard says it is not supported with AVoptionXL.
I tried Digitranslator 1.0 and it actually worked! (Thank you lightning ad). The drawback is ofcourse that the automation gain ( rubberbands) are gone, but then i thought; nevermind, what do i get paid for.... So for the next version of adrenaline upgrade i really hope i wont have to go back to OMFTool BTW Richard, if youre looking for digitranslator 1.0 get a [k]ed one... its easier than messing with floppies, dongles and xxxx.javascript:void(0) Thanks again to you all.. |
adam
Adrenaline and Protools 10? | azabu | Pro Tools 10 | 1 | 01-30-2012 12:22 PM |
Adrenaline hardware and Protools 10 | azabu | macOS | 0 | 01-28-2012 11:56 AM |
Problem ~ mixed-up titles... and more! | BionicDan | Avid Scorch (iOS) Forum | 8 | 07-26-2011 03:01 AM |
Video from an Avid Adrenaline | Jeremy Lock | Post - Surround - Video | 1 | 08-29-2006 09:29 AM |
How to import/export between PT 7.1 and Adrenaline | Makesound | Post - Surround - Video | 3 | 07-12-2006 12:13 PM |
