Old 05-26-2015, 09:14 PM
philip888's Avatar
philip888 philip888 is offline
Default PT 12 and Windows and Sam ASH Warning.
Just saw this any one hear of this?
It Warns of problems with the H81M Chipset.
Gigabyte EX58A-UD3R BIOS FH, Intel Core i7 CPU 980X, 24GB Mushkin Enhanced Blackline DDR3 1600Mhz PC3-12800, NVIDIA GeForce GTX 560, Windows 10 Pro 64 Bit, Pro Tools 12.7
Old 05-27-2015, 08:01 AM
Benoni's Avatar
Benoni Benoni is offline
Default
Interesting info.... but what is the problem? The USB3 ports? Or the graphics? If it's graphics, then a dedicated graphics card may be the solution.
Brian
Windows 11 Pro | macOS 12
Pro Tools 2022
benonistudio.com
Youtube Channel - benonistudio
Plugin Deals
@benonistudio
Old 05-31-2015, 10:35 AM
deepsouthguitar deepsouthguitar is offline
Default
I'm getting and everybody I knows saying pro tools when they started the compatibility change where they started Unsupporting things has put a lot of distrust in people in avid there's alot of money being spent on equipment and hardware that's it's not worth it in the long run
Old 05-31-2015, 08:04 PM
zedhed's Avatar
zedhed zedhed is offline
Default
Could you please repeat that?....preferably in English.
Too much blood in my drugstream
Motherboard: Gigabyte Z690 AERO D
CPU: Intel Alder Lake Core i9-12900K
CPU Cooler: Noctua NH-D15S
RAM: Corsair Vengeance DDR5 64GB (2x 32gb 5200MHz)
Drives: 2 x Samsung 980 Pro 2TB NVME PCIE 4.0 M.2 SSD (Record & Samples)
1 x Samsung 980 Pro 1TB NVME PCIE 4.0 M.2 SSD (OS Win 11 Pro)
GPU:Gigabyte GeForce RTX 3060 12GB GDDR6 PCIE 4
PSU: Corsair HX Series HX850 Platinim
CASE: Fractal Define XL R2
PT 11HD (v11.3.2) Omni s/pdif <> AxeFxIII
HD 96I/O
Old 06-01-2015, 02:07 AM
Default
I'm saying I'd think about it before I'd buy pro tools because four or five years down the road plug-ins won't work. If you have s hard drive go out and you need plugin downloads or you need things to get you back up running won't happen your screwed
Old 06-01-2015, 07:11 PM
zedhed's Avatar
Default
I don't think what you are saying has anything to do with the topic of this thread.
HD 96I/O
Old 06-02-2015, 10:52 AM
The Weed's Avatar
The Weed The Weed is online now
Default
I'm not sure I understand the comment either. I updated from PT LE 8 to PT 11 and now 12 when a) it was time after 7+ years to upgrade my computer and b) my third party plug-ins were updated to AAX64. I have backup images so that if a hard drive goes out I can easily be back up and running with little fuss and, while I have copies of all my software downloads I also have the ability to download my software from my accounts if I want/need to. A little foresight, planning, budgeting and backup strategy will take you a long way.
Now back to the question at hand. I found this on a gamer website, but it's also applicable to computers used for audio:
"H81: As with H61 and other HX1 predecessors, H81 is most at home in "living room PCs" and use-focused HTPCs. You lose all advanced storage functionality, drop 2 of the SATA ports, drop to a single x16 PCI-e slot, lose 2xPCI-e 2.0 lanes, and lose one DIMM per channel (meaning you're restricted to 2 memory slots). There's no overclocking support and BIOS is effectively relegated to controlling your boot devices, seeing as there's not much else to do in there.
I've already stated this throughout the above text, but we can simplify things pretty heavily:
  • If you enjoy playing with settings, tweaking, and getting your hands dirty in DIY-type modifications, then opt for Z87 and K-SKU CPUs.
  • If you don't care for any of the above and simply want to play games and leave BIOS alone for the duration of the system's life, opt for H87.
  • If you're building a function-limited HTPC or desktop machine, consider H81, but favor H87 for its higher build-quality."
While I salute Sam Ash for at least being concerned about their customers Windows computers as far as Pro Tools is concerned, I think it would be more appropriate to advise their staff to ask about the computer rather than saying they "can't confidently recommend Pro Tools 12 to any customer running it on Windows..." which is probably as far as the sales type is going to get in the memo. Talk about negative marketing.
Cheers,
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
Old 06-02-2015, 12:35 PM
Craig F Craig F is offline
Default
who is dumb enough to take tech advice from the SA/GCs of the world?
Thank you,
Craig
Old 06-04-2015, 07:14 AM
Bob Olhsson's Avatar
Bob Olhsson Bob Olhsson is offline
Default
The problem with windoze is that you've always been able to get really crappy cheap computers that aren't good for anything more than web browsing. The good PCs aren't much cheaper than macs but can be upgraded and are compatible with a much wider range of software versions.
Bob's room 615 562-4346
Interview
Artists are the gatekeepers of truth! - Paul Robeson
Old 06-06-2015, 04:49 AM
NewdestinyX NewdestinyX is offline
Default Re: PT 12 and Windows and Sam ASH Warning.
Yes… It's always blown my mind how Windows users scoff at Mac users for spending so much money on a desktop DAW. If you've ever read Avid's list of requirements for a PC capable of running a hi track count ProTools-based DAW smoothly, you're still going to spend almost as much as a Mac Pro. Avid even gets as specific as to what motherboard type and graphics card type you need installed in a PC. There are no free rides when you're wanting a problem free ProTools DAW.
Rig 1-Mix/Mast: PTHD 11.3.1; MacPro 6core (6,1) 3.5 GHz Xeon E5; 10.10.3 (SSD Drives for audio); Apogee DUET, FireStudio2626 as Hware Inserts to PT for outboard
Rig 2-Cutting&Remotes: PTHD 11.3.1; MacBook Pro (8,1) 2.8 GHz Dual i7; 10.9.2 (128GB int '6G' SSD drive); Profire LightBridge (FW800), 32ch Presonus Digimax FS
WARNING: Pro Tools 10 for Windows is ABYSMAL. JamesClark1991 Windows 16 12-03-2012 02:30 AM
A warning to all! Aussie169 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 07-31-2006 03:46 AM
has anyone seen this warning? lbmusic 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 08-08-2004 09:12 PM
OT: warning! where02190 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 09-04-2003 05:35 PM
Hey everyone! warning O.T.-O.T. GORILLA 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 10 08-31-2003 05:56 AM
