Duplicating Tracks does not duplicate audio quality
My technician has observed that when duplicating a track, the duplicated clip does not sound exactly the same as the original track's clip. Whereas when you copy-paste a clip, it does sound exactly the same as the original clip. I would like to know what may be causing the duplicated track's clips to sound different than the original track's clips. Is the Pro Tools software programming making this difference when a track is duplicated, as opposed to when it is copy-pasted?
JKayL |
Re: Duplicating Tracks does not duplicate audio quality
I assume there's no plugin involved. How did he noticed that? What happens when you reverse the phase of the duplicate and mix down to mono?
Dell XPS 8700. Intel Core i7-4770 CPU @ 3.40GHz. RAM: 16GB. Windows 10 Home x64. NVIDIA GeForce GTX 645. NI Komplete Audio 6. Pro Tools Software 2019 amagrasmusic.com |
Hi, I just duplicated a track and inverted the polarity and it nulls out perfectly.
Are you running the duplicate through the same output as the original? Are you selecting all the track data to be duplicated as well? |
Routed to different hardware outputs? No reason they shouldn't be identical.
Ben Rubin Producer//Mixer//Bassist//Composer benrubin.com ------------ PT Ultimate 2024.3, Mac Studio M1 Max, 64Gb RAM, Mac OSX 13.6.4, SSD sample drive, Neve 8816, HD Native Thunderbolt, (2) Lynx Aurora 16, Benchmark DAC-1/ADC-1 |
There is workaround for this issue. Always delete original track after duplication!
Nobody else than your technician would have chance to compare the quality |
Mike
Intel Core i7 4790K 4.0GHz | Asus Z97-Pro LGA 1150 Intel 6Gb | Corsair Vengeance Pro 32GB DDR3 2400 | Asus GT640 Silent 2 GB GDDR3 | Samsung 850 Pro SSD's, WD Caviar Black HDD's | PSU Corsair 750W ATX12V | Windows 10 | Presonus Studio One | 003R PT's 12.8 | Waves Platinum | Ivory/Piano | Berlin Woodwinds, Nocturne Solo Violin | SPITFIRE Solo Strings | EastWest Hollywood Strings, Brass, Pro Drummer, and Stormdrum 2 | VSL | Vienna Ensemble Pro | M-Audio Code 61, FaderPort 8 | |
There's something tricky with this title: Duplicating identical audio tracks should only put more volume......
splitting stereo tracks to mono -- audio quality? | mcconnellsteve | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 10 | 04-10-2023 09:45 AM |
Strange problem with audio/midi tracks after copy/duplicate | Nullfusion | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 09-25-2011 07:17 PM |
Smile Strange problem with audio/midi tracks after copy/duplicate | Nullfusion | Pro Tools 9 | 1 | 09-16-2011 04:35 PM |
Is there ANY loss of quality when duplicating? | cheekypaul | Tips & Tricks | 2 | 02-22-2005 10:18 AM |
How to improve audio quality when bouncing tracks | krhaarmeyer | Tips & Tricks | 1 | 12-31-2000 12:37 AM |
