Old 01-11-2010, 06:03 PM
Jupiter4 Jupiter4 is offline
Default Midi note input before grid point problem!
Hi, not sure if this has already been covered but I couldn't find any posts about it.
I've had this annoying problem for years and have never solved it. Basically when inputting midi notes in grid mode, PT seems to sometimes put the start of the note just a tiny bit before the grid line so that when I go to select a region, for example to duplicate a bar, some of the notes at the start of the selected region don't get selected. Duplicating/copying sections in region mode results in the same problem.
This also causes problems if there is the same note repeated directly before, as the overlap causes the offending early placed note not to be retriggered.
To get around this I have to zoom in on the offending notes and trim them back to the grid line where they are supposed to be. I'm currently using Pro Tools & Kontakt to write an orchestral film score with about 20 parts/midi tracks, so this continual re-trimming is getting very tedious and time consuming.
I've got a feeling this is just a built in bug and if I upgraded to PT 8 it would probably be fixed but I don't have time to upgrade OS X and PT and then deal with all the plug-in/software incompatibilities that will inevitably crop up.
Is there a way to set the midi note start point? I'd even be happy with all notes starting a few samples late...
I'm running Pro Tools LE on an original Mbox with OSX 10.4.11
Thanks in advance!!
Old 01-12-2010, 07:50 AM
sguy006 sguy006 is offline
Default Re: Midi note input before grid point problem!
Same annoying issue with me,m using PT 8.0.3,still the same problem..
Sandy
iMac 27" 2020
Protools 2022.7
Protools Carbon
Old 01-12-2010, 07:59 AM
SpinningDisk's Avatar
SpinningDisk SpinningDisk is offline
This is a stupid question but have you checked to see what your grid is set at (1/4, 1/2, 1/8 notes)?
Old 01-18-2010, 10:04 PM
Yep I frequently change the grid value but that shouldn't make any difference to the start point of the note should it?? Anybody have any ideas? Digidesign - any chance you guys could fix this?
Old 01-18-2010, 10:35 PM
dubaifox dubaifox is offline
This is a very old and persistent problem.
I have seen it from early vs 6 days.
International Award Winning Arabic Fusion
www.ajmusiconline.com
2xMacPro 2.66,002r,OSX 10.4.10,PT 7.4cs8
3xVisionDaw,NI Komplete,Yamaha 01V/96
Old 01-19-2010, 02:30 AM
midi sordino midi sordino is offline
Is this still a problem when you quantise the notes in grid mode?
Old 01-19-2010, 02:46 AM
smilie smilie is offline
in pt 8 is a little easier to work around this than in previous version
and yes even after quantizing the notes there's always that problem.
a good way to deal with this is to set the HW buffer to 256 or mayb lower
Its funny because i been seeing this problem for years but i thought is just me
that had the timing problem
Old 01-19-2010, 02:53 AM
RussUK RussUK is offline
It is a PITA but in 8 it's easily fixed. Open the track in midi editor and click on all the selected notes, it then aligns them all the grid and then the cutting in the edit window works. I use it more than quantize.
I work with amazing people who do incredible things.
Founder of the Expert Sites.
Old 01-19-2010, 03:10 AM
What exactly is the problem? The OP's problem involves having to trim notes that are early. Most likely cause is a simple one and not a mysterious timing bug, i.e. they were played early, the hardware buffer is set too high, they are not quantised. My notes are all spot on to the grid when quantised. Can someone explain more clearly what this so-called persistant midi problem is?
Old 01-19-2010, 07:02 AM
I don't play them in, I pencil them in. So, in grid mode with the pencil tool, I click on a spot in the bar where I want a note and it draws it, but that note sometimes is in the right spot and sometimes looks likes its in the right spot but is just a tiny tiny imperceptible bit early so therefore isn't selected if the selection starts at that grid line. When I'm writing a detailed complex arrangement, theres hundreds and hundreds of midi notes that I've penciled in, some of which won't be selected when I select a section in grid mode to duplicate or copy etc. Really annoying.
Midi 101 really missing? Set high note/low note on track's input robinsonsdca macOS 4 11-10-2011 01:23 PM
Track Input Midi Note Range Limiter? HighNote/LowNoteSet robinsonsdca macOS 0 11-08-2011 02:49 PM
Midi note records before auto punch point smpkeys 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 01-27-2010 12:26 AM
quantizing from whole note grid to 1/4 note grid Dead River Studio MIDI 3 03-07-2003 05:40 PM
Quantized MIDI Note Info not Highlighted According to the Grid electrobank 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 11-21-2002 04:38 PM
