Go Back   Avid Pro Audio Community > Other Products > Storage Subsystems
Old 06-22-2005, 04:35 PM
dancow dancow is offline
Default Re: Audio Record Volume
Has anyone resolved this? I just installed Pro Tools 6.9 on my new G5 (10.4.1) and I am getting the 'session must be on an audio record volume' error. When I go to Windows=>Show Workspace and try to change my drives to enable audio record, it says the drives cannot be designated as an audio Record volume because it is not a valid audio volume. I have two drives, they are default Mac formatted drives, and I have stuff on them I can't delete, so I don't want to wipe them clean. I've verified and repaired permissions, still nothing. I've dragged the digidesign databases to the trash and re-started. Still isn't working.
This is kind of a show stopper, someone please advise.
Dan Cowles
Sr. Video Producer
Macromedia, Inc.
Old 06-22-2005, 05:45 PM
You'll have to format them using the Disk Utility.
Rail
Platinum Samples
www.platinumsamples.com
Engineered Drums for BFD
Old 06-23-2005, 10:54 AM
DigiTechSupt's Avatar
Sorry, Dan, but you'll need to back up the data on those drives and format them with the OSX Disk Utility.
Usually the drive format coming from the factory is not correct - they will mount just fine, but Pro Tools and some other applications will not be able to use them properly.
Always format new drives with the Disk Utility before using them.
Avid Audio Tech Support
Support FAQ
Old 06-25-2005, 10:40 PM
sleadley sleadley is offline
I had this problem just recently and I discovered that the problem was due to the DigiMachOservices in the frameworks folder of the Library. These were the wrong version for the LE version that I was running. I think the problem was that I had been using the Computer (a G4) for TDM then I uninstalled TDM (using the safe method) and installed LE. This did not replace the DigiMachOservices with the correct LE versions. I did a complete deinstall (full version) then a complete install and all worked correctly. Try this it will work.
Regards
Simon L.
Plan for the worst, Hope for the Best.
www.trackdown.com.au
Old 08-01-2005, 09:02 PM
enormous enormous is offline
Am having same issue. Tried all of the above, reformatting my audio drive (OSX Extended, Journaled), deleted all protools prefs & dBs, repaired permissions, clean-uninstalled PT & reinstalled, still no luck. I am trully stuck on this one. Brand new G5 dual 2.3, OSX 10.4.2, 002 Rack PT 6.9. I am tired and going to bed now. Digi and/or somebody... PLEASE HELP!!! Thanks!
  #16
Old 08-04-2005, 10:34 AM
You need to update to Pro Tools 6.9.2 for compatibility with Tiger, OS 10.4.x.
Support FAQ
  #17
Old 08-10-2005, 10:37 AM
Irl Sanders Irl Sanders is offline
Hi -
Just installed LE 6.9 w/ DV toolkit on two identical (and virgin) dual 1.8 G5s running 10.4.2
Problem on one of them -
The 2nd 400g SATA drive, diveded into three equal partitions, and formateed with Disk Util to Mac OS Extened Jornaled will not be recognized as audio volumes. Have reformatted several times, with journaling on and off. Sometimes PT will recognize the drives immediatly after formatting, but the next time you launch it it goes back to the "seesion must be on a valid audio drive" routine.
Any thoughts?
Irl Sanders
Music Editor
LA, CA, USA
  #18
Old 08-11-2005, 07:11 PM
DLINDSA21 DLINDSA21 is offline
I tryed the re-instalation of the pro tools and Im getting the same message when I try to Change "A" column space in (WORK SPACE) to Record
  #19
  #20
Old 08-22-2005, 04:35 PM
dave898 dave898 is offline
If you are using PT LE 6.9 with Mac OS 10.4 (tiger), you must download and install version 6.9.2 from Digi's website. I had all the problems listed above, and once I installed 6.9.2, all my drives became available as audio record volumes (even the ones that I did not reformat with OSX Disk Utility).
cannot be designated as an Audio Record volume because it is not a valid audio volume Gav_Russell 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 02-15-2016 03:52 PM
Cannot be designated as an Audio Record Volume because it is not a valid Audio Volume soloavenger macOS 7 02-15-2016 03:49 PM
Session must be on an audio record volume if permmited set the volumes to R record lionandthemouse 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 03-11-2013 01:48 PM
hd cannot be designated as an audio record volume because it is not a valid audio wapeddell 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 17 04-12-2010 12:05 PM
cannot be as an audio record volume because it is formatted as a FAT volume rtm Pro Tools TDM Systems (Win) 3 12-18-2008 09:52 AM
