Old 02-08-2011, 06:23 AM
critictalk critictalk is offline
Default PT LE8 requirement
My PC is XP(Traditional Chinese version) SP3 32bit
AMD Athlon 64 x2 Dual Core Processor 5200+
4 GB Ram
ATI Radeon HD 3200 Graphics (on board)
Gigabyte GA-MA78GM-US2H motherboard
Can I install Mbox2 + PT LE8??
Old 02-08-2011, 09:38 AM
Default Re: PT LE8 requirement
It might work with one change. Integrated graphics don't work, but you could disable that in BIOS and install a PCI-e graphics card. I would try that with a "middle or the road" nVidia card. Even if it doesn't work, at least you made an improvement
Old 02-08-2011, 01:34 PM
mano111 mano111 is offline
It might work with integrated. This is a relatively powerful integrated chip and not part of the chipset like Intel's.
Then again I wouldn't be surprised if it doesn't. You'll need to try it and let us know.
i7 2600K @ 4.4GHZ -- Intel DP67BG B3 -- 8GB DDR3 1600 -- Crucial SSD
PTLE 8.0.4cs2 -- DIGI 003R -- DV toolkit -- Waves 9
Old 02-08-2011, 02:14 PM
misterdmz misterdmz is offline
I had PT8 running on that same processor running at 2.7 with the integrated graphics on an Asus mobo without problems. I did eventually install a PCIe vid card. The system ran just fine for the few months before upgrading to an i7 rig.
Old 02-08-2011, 03:16 PM
Glad some are having success. Keep in mind that integrated graphics is using part of your RAM(which also will happen to a lesser degree with a new graphics card so I recommend 256 or 512mb only. Save the 1gb graphics cards from when you move to Windows 7 64bit).
Old 02-08-2011, 08:12 PM
How about the traditional Chinese version of windows XP?
Will it be a problem?
Old 02-17-2011, 11:26 PM
Well , I have installed mbox mini 3 and LE8.0.4, so far so good
Anyone Seen This NEW System Requirement for HDX? gives Pro Tools HDX & HD Native Systems (Mac) 17 01-02-2012 08:05 PM
Is USB a requirement for XP? Pierre B. Samson 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 07-28-2002 04:34 AM
Is USB a requirement for XP? Pierre B. Samson 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 07-27-2002 10:16 PM
RAM Requirement Mount Royal 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 01-05-2001 04:45 PM
5.1 DSP minimum requirement. Chris Lambrechts General Discussion 9 11-14-2000 05:11 PM
