using external mic pre\'s...
How's the best way to bypass the mic pre's on chnls 1-4... I'm currently coming out of my external mic pre's and into the TRS inputs on the back of the 002R...thanks...
Mac G5, 10.5.8, 2 GB, Rosetta 800 w/X-HD Card, Control24, HD2, PT's 8 http://carterbrothersband.com/studio.cfm |
Re: using external mic pre\'s...
All you need to do is set your 1 thru 4 to Line/INST and then hook your pre to the 1 thru 4 TRS input. Sounds like you already did that.
Doc
MONUMENT SOUND MONUMENT SOUND ON YOUTUBE Monument Sound Facebook "Changing how people hear music one track at a time" |
Yeah, I do... but chnl 1 on the 002R got accidently moved without me knowing it... I spent 30 min trying to figure out why I was getting so much gain out of chnl 1... the gains still work on 1-4 when everything is set to line input... strange..
You using a 002R or the console?
I'm using a C24... loving it. I have the API 3124 (4 pre's), Grace 802 (2 pres), UA6176 (1 pre), Digimax and some other things.. so I don't need the console or 002R pre's.. I'd just like to bypass them all together..
External Pre's with Mbox Pro 3 | AnnexProjekt | macOS | 2 | 03-02-2013 01:12 AM |
External Pre's and Mbox2's | JazzyJ | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 08-30-2012 01:53 AM |
Sync between 002, external optical pre's and O2R | Forrester | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 12-15-2005 05:31 AM |
Questions on using external Mic Pre's with 002? | stingerns | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 10-27-2005 12:53 PM |
Routing An External Compressor Thru 001's Pre's | Bloux | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 01-18-2003 08:03 PM |
