Old 09-30-2008, 12:25 PM
EnxStudios EnxStudios is offline
Default High-Pitched Noise when in PT
Hey guys whats up,
New here to the forum and decided to ask this question before anything..
I have an Mbox 2 Mini, USB to my HP Desktop.. Now when im not using any audio apps, like PT or FL Studio.. I hear no noise at all.. good, but when using PT or FL, i get this high-pitched noise from the interface.. through my monitors.. It does not mask out the audio.. It lets me work, but sometimes gets really annoying.. tried it on other pc's, same thing, tried it on my MacBook, no noise.. even though its connected to the same power strip.. What can this be, and how should I fix it.. If i can.. Thanks..
Kalet
Old 09-30-2008, 02:35 PM
DigiTechSupt's Avatar
Default Re: High-Pitched Noise when in PT
See the General Troubleshooting thread - it has several suggestions for fixing this problem.
Avid Audio Tech Support
Support FAQ
Old 09-30-2008, 03:45 PM
Thanks for the fast response.. Im going to try all these out.. Hopefully it fixes the problem.. Thanks again.
Old 09-30-2008, 04:11 PM
LSW LSW is offline
I still have the original MBox, and recently got a new desktop and suddenly I got the noise. Researched much, even bought a monster USB cable which worked for some. Not me. Finally, I plugged in my monitor amp into a different circuit and all was well.
Old 09-30-2008, 05:49 PM
So your saying it was not the interface.. It was your monitors.. Cause i have it connected to the pc and i get that sound.. but i also have a MacBook, and it is connected, in the same circuit, monitors in same place, and interface in same spot and I dont get the noise anymore...?
Old 09-30-2008, 06:23 PM
LSW LSW is offline
It was definately being generated by the PC, as it didn't happen on my old one. But for me after trying everything that was suggested the only thing that worked was what I ended up doing. I'm sure there's some sceintifc explanation, but I wouldn't know what it is, something to do with grounding I suppose.
Old 09-30-2008, 06:26 PM
Yeah I think that it does have to do with Grounding... but i need an easier way out of it other than taking the PC apart..
Old 10-01-2008, 02:32 AM
mano111 mano111 is offline
A freind of mine had this a type of high pitched nose with Mbox 2 mini going to a Mackie mixer then to Event monitors. Replacing all audio cables (4 in total) with balanced cables fixed it.
i7 2600K @ 4.4GHZ -- Intel DP67BG B3 -- 8GB DDR3 1600 -- Crucial SSD
PTLE 8.0.4cs2 -- DIGI 003R -- DV toolkit -- Waves 9
Old 10-01-2008, 01:09 PM
adu808 adu808 is offline
i have the same problem...except it goes away when i by pass my mixer.
Old 10-02-2008, 07:20 AM
SixChurchStreet SixChurchStreet is offline
May very well be the ground loop problem. Does the "whine" change and vary when you move your mouse around, click on things, open plugins, etc?
One solution is to get a cheapo ground fault loop isolator like this...
http://cgi.ebay.com/GROUND-LOOP-ISOL...d=p3286.c0.m14
replace the cables running to your amp or powered monitors with that. now, this can dull your sound ever so slightly. but it didn't bother me much.
but finally I figured out if I plugged everything into the same power socket, my noises went away. Even in different sockets in the same outlet, I got noise. I have one powerstrip connected to the wall, and all other powerstrips plugged into that one. anything else that's physically connected to your system, but plugged in somewhere else can introduce noise though (like a reamped guitar amp or something like that), so keep that in mind.
Mac Pro 5,1 2.4GHz 8-Core 16GB RAM High Sierra | Focusrite Scarlett 6i6 Mk2 | Pro Tools 2020 | Studio One 4
high-pitched noise from psu dave192 Pro Tools M-Powered (Win) 1 09-11-2010 04:43 PM
High pitched noise while recording Bob Vivian 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 07-05-2009 07:26 PM
High pitched noise from Mac via Mbox2 djmoss Pro Tools TDM Systems (Mac) 3 05-01-2008 07:55 PM
High-Pitched whistling noise bmwgoose 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 02-02-2008 01:12 PM
High pitched noise on Mbox 2 .... trippy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 04-09-2006 10:59 AM
