Re: Another OMNI Optical Issue
It comes out from Mac Pro 2013 to the optical in of the HD Omni. The firmware is the latest of the HD Omni, and Pro tools I can say I use this since PT HD 8 till PT HD 12.7.1 Did you try to reset your HD Omni to default?
Marco Bernardo Dialog Editor, Sound Designer, Re-Recording mixer nMacPro 6Core/D500/512GB/64Gb ram | PT HD 12 HDN Thunderbolt | HD OMNI | Avid Artist Mix | Novation Impulse 25 | Waves Mercury Native | Audioease All In Bundle | SoundToys | McDSP Classic Pack | DUY Overpack | Arturia Beatstep Pro |
I did reset it. That didn't help. My firmware is version 2.10. Is that the newest? Thanks, Ryan
Ryan McCambridge Producer • Sound Designer • Mixer |
Yes, 2.10 is the latest.
Thanks again Marco. I appreciate it. Ryan
For anyone that's interested:
I ended up buying a Monoprice Optical to SPDIF converter and plugged the optical cable from my MacBook Pro into it, then out to the SPDIF in on the back of the OMNI. In the Hardware setup, I switched the "Digital 1-2 Input Format" to S/PDIF, then made sure that the "S/PDIF 1-2" had both "MON" buttons on on the Mixer page, and everything worked instantly. So I'm not sure if my optical input is messed up but for those who are interested, that's how I solved my issue. Thanks again to everyone that helped out. Ryan
#16
The only difference in my rig is that I have the Optical(S/PDIF) set to Main 3/4 instead of 5/6. Don't remember why. The only thing wrong with my system is that when I first start up I have to run some audio through iTunes to get the OMNI to sort of "wake up". It makes an unpleasant "pop" and then everything is great. If I don't do that, all playback from Pro Tools has distortion.
The setup allows me to select the optical out from the Mac as a source and record it into Pro Tools. Sorry this is giving you grief. Good job finding a workaround. Peter
Gypsy: PT Ultimate 2019.5, 12-core Mac Pro 3.46Ghz 64GB OS 10.14.5, HD Native, HD OMNI, 2 Artist Mix, EUCON 18.3, Presonus 32R, Studio One 4.5.1, Quad Eight preamps, Neve 3201 EQs, 2 LA-4s, Malone Design Works desk Laptop: 10.13.6 MacBook Pro 2.8 Core i7, 16G, PT 19.5 Live 9 www.remotewest.com @RemoteWest |
#17
Ryan
#18
Very odd. I've been using the optical in on my Omni to feed the optical output of my MacPro through my main monitors, and it works for me. Although, there is an occasional click from a a sample rate clock mismatch. But it still works. I'll post my settings. The only thing that is really different is that I don't have 'Use Tascam format' selected. Have you tried without that?
Pro Tools Ultimate, HDX3 & MTRX + HD MADI 7,1 MacPro, 3.2GHz 16-core, OSX 10.15 S6 M40 48-5, panners, MPM,Dolby Atmos RMU AJA Kona LHi, Sync HD www.ToolshedAudioPost.com www.TheToolshedStudio.com Certified for Dolby Atmos Home Entertainment |
#19
screenshots of my settings...
#20
I have used my Omni with SPDIF for a long while as well. I use the optical out of 1 of my TV monitors using the Nvidia audio driver into my Omni. Maybe my Mixer is backwards but I have to pull the faders down to get the volume to increase out through monitors.
Sent from my iPhone using Tapatalk Pro |
HD Omni Optical | GaryCar | Pro Tools HDX & HD Native Systems (Mac) | 1 | 09-10-2015 07:52 AM |
MacBook Pro Optical out into Omni optical In? | KenSluiter | Pro Tools HDX & HD Native Systems (Mac) | 2 | 01-14-2015 04:37 PM |
Omni optical out....for 5.1 monitors.. | PT user | Post - Surround - Video | 5 | 07-15-2013 11:14 PM |
Trim Optical Inputs on OMNI? | dwaynedelario | Pro Tools HDX & HD Native Systems (Mac) | 13 | 03-13-2013 01:34 PM |
Clock Issue on 192 i/o Optical [ADAT] Not Optical [Encl] | Willard | Pro Tools TDM Systems (Mac) | 1 | 10-10-2007 01:23 PM |
